newbie looking for info on wrangler styles... - JeepForum.com
post #1 of 4 Old 05-14-2002, 02:03 PM Thread Starter
blamejane
I can't wait to purchase a jeep (my first)...
Can someone give me the link to a place where I can read about the differences in the various wrangler (YJ) styles? Hopefully with information and pictures, but I'll take what I can get.
Sahara, Olympic, Islander, Renegade, Laredo...
thanks
blamejane is offline
post #2 of 4 Old 05-14-2002, 03:00 PM
rlasker3
I wouldn't worry about the different models. As far as I know they are only different option packages. Just concern yourself with getting the specific engine you want and whether you want a hard or soft top (or both). From there you need to determine what you want to do with this vehicle. Are you going to go off-road? If so how much? If not, then don't bother with big over-sized wheels as they'll only drag down your gas mileage and make the ride rougher.
The great thing about Jeeps are that they are easy to customize to your liking so looking for a specific model type will only needlessly limit yourself in your selection.
Just find a good deal that at least has the basic features that you want and then customize from there.
Good luck.
rlasker3 is offline
post #3 of 4 Old 05-14-2002, 03:23 PM
RCHavok797
RCHavok797's Avatar
I have never heard of the Olympic model but the only difference in appearence of the models is the Renegade of the early 90s Wranglers. It has a different trim package than the other Wranglers. There really aren't any major differences in the other models, the only other thiing you really need to concern yourself with is what engine the Jeep has. From 87-90 the Wrangler came with the carburated straight six 4.2L and from 91 to present it came with the fuel injected 4.0L straight six. It also came with a 4 cylinder engine that is mainly the same from 87 to present with slight changes. Good luck with fiding a Jeep, I know you will love it.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #4 of 4 Old 05-14-2002, 03:24 PM
MusicMaverick
MusicMaverick's Avatar
2014 JK Wrangler
87-89 4cyl had 2.5 engines putting out 105hp and the 6 4.2 put out 112hp. 90-95 they upped the 4 2.5 to 120hp and changed the 6 to a 4.0 putting out 180 and in 91-95' up to 190hp. In 90 all Jeeps became fuel injected. Before then only 2.5's were fuel injected.
Somewhere halfway through 89' they changed the tranny's on the 6 to AX-15's and doing away with the junky peugout trannys. I THINK they had the AX-5 from 87-95 but I could be wrong. I know they had it after 90 tho.
In 92'they changed to full cage roll bars. And only 87' has a weird soft top set up that can be hard to get a replacement as compared to 88-95.
Also in 92' they changed the dash guages to newer styles and got rid of the clock. As for the editions like you mentioned. They are just options packages and decal sets. My fav year is 91' cuz it has a good engine fuel injected and I like the old style roll bar.
Currently: '14 JKU
Past vehicles: '92 YJ, '97 TJ, '10 JK
MusicMaverick is offline
newbie need info sh13lds21 TJ Wrangler Technical Forum 34 09-22-2009 08:28 PM
different leaf styles jeep795 YJ Wrangler Technical Forum 3 10-07-2006 08:00 AM
Newbie needs clutch info.. Cajunborn YJ Wrangler Technical Forum 16 03-25-2005 08:16 AM
NEWBIE-need a 92 Sahara info sahara YJ Wrangler Technical Forum 13 10-20-2002 12:41 PM
Newbie needs info! Supra4x4 YJ Wrangler Technical Forum 12 10-17-2002 11:24 AM
