Newbie Jeep owner w/ a newbie Jeep question - JeepForum.com
post #1 of 13 Old 02-27-2005, 06:56 PM Thread Starter
bigjim72
Im a 32 year old father of 2 who just purchased his first jeep, with his main intentions on being very little everyday driving, and a lot of extra curricular driving with his sons for some fun. Since this will not be my primary vehicle, I have some leeway to have things done to it....
So, I just got a 97 Wrangler with a 6 inch lift and 33 inch swampers....Im totally thrilled with this monster, and the only thing Im not cool with is the steering. It has tons of play in it, and when Im driving, I sometimes feel like I have to jerk it to have it respond. I had kind of assumed that this was just the nature of the beast with owning a jeep, and I was going to have to live with it. However, I did notice that in 4x4 high, it drives a thousand percent better....Seeing as this is my first jeep, it struck me as wondering if it was OK to ALWAYS drive in this mode, or if it would destroy something. Also, if its cool, can I assume it will consume considerably more gas?
Thanks in advance for the help, and although I just found this board a few weeks ago, it did help me enough already to buy my first jeep, so for that I thank you!!
bigjim
bigjim72 is offline
post #2 of 13 Old 02-27-2005, 07:01 PM
chopperkid2000
Welcome : Well w/ a 6 " lift that is to be expected as the drag link is now push pull rather than left right. But 4w high being better ? puzzling . Nah should really not make it drink more gas !!!Nor should it destroy anything - just make front gears and t case insides wear faster !!! To fix the steering there is high steer kits out there but they cost alot of money most peeps, just deal w/ it
chopperkid2000 is offline
post #3 of 13 Old 02-27-2005, 07:03 PM
Silver yj
You can't drive in 4 hi all the time or you will burn it up. As far as the loose steering check the tie rods, bearings, ball joints, steering wheel shaft to P/S box
Silver yj is offline
post #4 of 13 Old 08-11-2009, 04:54 AM
Medieval2006
Yeah, ditto - driving in 4 hi will burn it up - and it will suck more gas than 2 wd.
Id put a bit of time and $$ into solving the problem instead of trying to cover up the symptom. Like most things with vehicles, it's probably only going ot get worse with time.
"Go ahead, take 'em off!"
www.TakeEmOff.com
Medieval2006 is offline
post #5 of 13 Old 08-11-2009, 08:54 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Need pics of the steering.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #6 of 13 Old 08-11-2009, 09:24 AM
TheNewbie
+1 on burning more gas in 4X4 and when you are in 4X4 your front wheels HAVE to turn at the same rate as your rear wheels which will cause binding and extremely accelerated wear and tear on the system if you drive in 4 wheel drive on a paved road.
When you're on a dirt road or ice it's not a big deal because the wheels can easilly spin at different rates, but there is too much traction on a paved road.
1995 YJ 2.5 - 4” RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #7 of 13 Old 08-11-2009, 09:28 AM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
Not that we are not here to help, but you also might try the TJ section, it is a '97??
X2 on the pics and checking for loose components!
Happy Wheelin'
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #8 of 13 Old 08-11-2009, 09:33 AM
Tony89
97 is a TJ so you technically posted this in the wrong forum. The steering on them is basically the same though, so in that respect I guess it really doesn't matter.
In a TJ, I doubt there is a considerable difference in mileage b/n 2WD and 4HI. The only difference in a TJ is the transfer case will actually be engaged.
98 XJ - 4.5" Lift, 32" BFGs, Lots other stuff
Tony89 is offline
post #9 of 13 Old 08-21-2009, 01:56 AM
latinheat
Try getting a steering damper ( stabilizer) and check your tie rods and make sure u grease ur fittings too.. doesn't hurt to get an alignment either.
Robert Schettini
latinheat is offline
post #10 of 13 Old 08-21-2009, 07:07 AM
asf06
do you have a track bar? not that you need one if you are gonna be driving off road all the time, but my jeep is my dd so i use the track bar. it makes the steering less jerky, i guess because it keeps the wheels from undulating.
x2 on the hy-steer. Max will set you up with that
x2 on posting in the TJ section
1993 YJ, too broke to swap the tranny and my 60s
Originally Posted by Rob99 View Post
It can't be a scam. There's pictures of Asian people in business suits pointing at charts and graphs.
PIKE Jeepers #1
Jeep Smokeless #4
asf06 is offline
post #11 of 13 Old 08-21-2009, 08:05 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
The OP has a TJ, which does REQUIRE the track bar to be installed at ALL times. Those TJ guys don't have the same options we do.
There are several options for steering arrangements. There is "crossover" steering like the JB4X4 type that move the drag link up, but not the tie rod. Then there is "high steer" like the Rocky Road OTT steering kit which has brackets that attach to the OE knuckle & move the drag link & tie rod up as well. The other & most expensive alternative would be to replace the knuckles with high steer units like the ones from Reid Racing.
I know all this exists for the YJ models, and to the best of my knowledge they are also available for the TJ's as well.
Max
Mean Max is offline
post #12 of 13 Old 08-21-2009, 08:46 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
With this fella being a TJ guy, and his LAST visit on this BB being June 6, 2006 I highly doubt we'll be offering much help.
Joe Dillard is offline
post #13 of 13 Old 08-21-2009, 08:46 AM
Peltboy25
let's not forget safety, as you're hauling kids in that beast. Steering is a fickle *****, and one second you're fine... the next, you can't find the "spot" to hold the wheel and you end up oversteering to find it. That's when the rolling starts. You have to get that steering checked and fixed for the sake of your boys.
Drive like you're going somewhere.
Peltboy25 is offline
Closed Thread
Hello am a newbie Jeep owner tosssweep Wrangler General Discussion 6 08-11-2009 11:19 AM
NEWBIE!!!!!!!Possible Jeep owner soon Please answer my ?s please 4mulaSvaliant YJ Wrangler Technical Forum 30 12-18-2007 06:40 PM
New 2001 Jeep owner, newbie questions... chrisman17 TJ Wrangler Technical Forum 5 01-30-2007 08:02 AM
Newbie Jeep Owner. 94 YJ wit 124K mi. YKnot YJ Wrangler Technical Forum 6 03-03-2005 07:42 AM
Newbie Jeep owner dbelshe YJ Wrangler Technical Forum 7 01-11-2004 05:23 PM
