Newbie here...need help with wheel/tire combo - JeepForum.com
post #1 of 2 Old 07-29-2010, 11:30 AM Thread Starter
Brent99
1987 YJ Wrangler
Just purchased a 87 yj and need help with deciding on new wheels and tires. Is it possible to put 30x9.5 tires on this Jeep without a lift? Also, I'm looking at the Crager Soft 8s in the 15" dia. version. What width would be best for this set up?
I did a search and could not come up with any answers. Sorry if I overlooked this elsewhere.
Brent99 is offline
post #2 of 2 Old 07-29-2010, 11:57 AM
Roadyy
You can run up to a 31" tire but will have a lil rub on the fenders without a lift. If you are going with a 9.5 then a factory 7" rim will be good unless you want to go wider later then an 8" would be the ideal rim to get, that way you can go up to a 12.50 wide tire later without having to replace the rims. just pay attention to the BS to keep it off the springs.
Roadyy is offline
Newbie, which lift kit and tire combo? FooKing TJ Wrangler Technical Forum 9 07-08-2010 12:49 PM
Wheel and Tire Combo lpmorgan TJ Wrangler Technical Forum 3 04-09-2010 07:06 AM
Wheel/Tire combo?? juiceparn Wrangler General Discussion 21 06-01-2008 10:00 PM
tire wheel combo drm822 TJ Wrangler Technical Forum 2 01-31-2007 11:19 PM
31x10.5x15 wheel tire combo on stock tire carrier? ADIDAS TJ Wrangler Technical Forum 13 06-24-2005 12:20 PM
