newbie form pa with a crazy coolant leak!! - Page 2 - JeepForum.com
post #16 of 27 Old 04-13-2010, 05:12 AM Thread Starter
DonCisco91
I read these cracks are more common on boat engines..
I kinda don't want to sell the Jeep though so i hope I can get it fixed...
DonCisco91 is offline
post #17 of 27 Old 04-13-2010, 05:23 AM
fitbmxseries1
1987 YJ Wrangler
engine swap! try car-part.com and search for a local yard with an engine they are pretty cheap and abundant in my area. this is the easiest vehicle in my opinion to replace the engine
fitbmxseries1 is offline
post #18 of 27 Old 04-13-2010, 06:17 AM
dodger889
You can get it fixed that will last the rest of the life time of the engine. You just have to find the right shop to get it done in. That is what is called a foundry crack. In today's world there are not many of the old guys that can do this type of work. But check in a diesel mechanical shop where they work on semis they might know of someone who still does this type of repairs. Or check with a restorer of old cars, pre1960's, they might should know too. For some of their work would be on engines that can not be found any more that need the casting work done to then.
That is on of the old arts that has been almost lost now days. But there are a few out there that can fix it just takes sometime to find them.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #19 of 27 Old 04-13-2010, 06:25 AM
FairlanePhil
FairlanePhil's Avatar
if you end up getting it welded look for a compitant shop by asking on this forum
460 Ford Forum - Powered by vBulletin
there will likely be a guy on there who will know of a shop near you.
They usually V out the crack and sometimes have to furnace heat the block then braze.
I had a shop in Toledo fix a small crack in my lifter gallery, they stick welded it. Some day Ill pull off my intake but I prefer living in denial
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is offline
post #20 of 27 Old 04-13-2010, 06:54 AM Thread Starter
DonCisco91
Cool, thanx for the suggestions. I guess i would have to price out what it would cost to get welded or if its better to do a swap.
post #21 of 27 Old 04-13-2010, 10:11 AM
matko25
go to a dirtbike shop and say you broke your case and you want this epoxy stuff by moose. my friend used it to fix his case and it actually has metal in it. it is made by moose racing i would say that would work
matko25 is offline
post #22 of 27 Old 04-13-2010, 10:21 AM
bharris68
Daily Driver
Metal Stitching is not that expensive, though it is involved. In effect the crack is drilled out and pins are drilled into the crack to replace the metal lost in drilling. Metal Stitching
I'd be cautious about troweling anything inside the block but "Stop Leak" of some sort should be effective on a hairline crack like that, IMO.
bharris68 is offline
post #23 of 27 Old 04-13-2010, 10:35 AM
matko25
Moose Racing 2010 it is called quick steel epoxy and is safe to use on steel and aluminum
matko25 is offline
post #24 of 27 Old 04-13-2010, 10:37 AM
matko25
actually just google quick steel epoxy and it gives you a ton of them and to apply them. i would try that first
matko25 is offline
post #25 of 27 Old 04-13-2010, 11:17 AM
Fernando
Fernando's Avatar
1987 YJ Wrangler
use JB Weld to fix it, I fixed a crack in a block with that and it holds to this day, and it was way more ugly than that one.
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #26 of 27 Old 04-13-2010, 11:37 AM
SloppyJoseph
I fixed a crack in my case on my CRF450R dirtbike with some JB weld. It threw the chain and cracked the case. It wasn't 100% but it was damn close. And it worked for over 2 years before I sold it. As far as I know it still is holding up.
SloppyJoseph is offline
post #27 of 27 Old 04-13-2010, 11:44 AM Thread Starter
DonCisco91
That jb weld stuff seems to do wonders. It may work even better if i can seal the crack from the inside by taking the water pump off. I will for sure try that.
Coolant leak sam24th YJ Wrangler Technical Forum 6 02-10-2010 11:03 PM
huge coolant leak/ creamy coolant?? 11Bgixx TJ Wrangler Technical Forum 17 01-11-2010 09:24 AM
Going crazy over a tank leak/Also dies when slowing - Stop lights Duffboy YJ Wrangler Technical Forum 6 10-06-2008 08:22 AM
Newbie With Crazy Wheel And Tire And Lift Question nippy JK Wrangler Technical Forum 14 04-24-2008 11:07 AM
It rained like crazy yesterday and my soft top (4door) did NOT leak! squid2004 JK Wrangler Technical Forum 14 09-07-2007 01:10 PM
