Newbe needing input on gear ratio. - JeepForum.com
post #1 of 3 Old 02-27-2002, 12:31 AM Thread Starter
holkster
What size tire can I run on a stock 3.07:1 gear ratio with a 3" suspension lift?
1999 TJ 4.0l I6 Stock for now!! 4.10 gears on the way 3" BDS in the garage with hopes of 33"x12.5 BFGs
holkster is offline
post #2 of 3 Old 02-27-2002, 12:36 AM
evilpsych
evilpsych's Avatar
well.. any size you want.. just you'll be waaaay slow outta the gate speeding up if you keep the 3.07's.. your best bet is to regear.. if you want 31's.. i suggest 4.10's..; 33's 4.27's; 35's 4.56's or 4.88's; and so on and so forth..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #3 of 3 Old 02-27-2002, 05:49 AM
bobznew
This should help you out:
http://www.4wheelparts.com/Tirel_Gear_Ratio.asp
'97 ZJ, 4.0L, Gibson Cat-back system, Daily Driver
'95 YJ, 4.0L, 3.5" BDS suspension lift, Boomerang Shackles, BDS Shocks, 33x12.50 TSL's, Lock-Rite in rear, No-Slip up front, Posi-lok, Warn XD9000i winch, and a ton of dried Mississippi mud!
bobznew is offline
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 06:40 AM
needing new speedo gear trav_k1234 TJ Wrangler Technical Forum 2 11-24-2008 09:04 AM
gear change another newbe question RobertWH YJ Wrangler Technical Forum 7 08-07-2008 07:14 AM
Gear Carriers for gear ratio swap bwiencek YJ Wrangler Technical Forum 1 05-04-2006 09:52 AM
