Newb: I need help - JeepForum.com
post #1 of 8 Old 09-26-2007, 07:44 PM Thread Starter
wayfastwhitey44
Newb: I need help
I'm new here and looking for some help bought a 95 yj 2.5 back in march ran good till about a month ago it was hard starting in the mornings when it was cold then once i got it started witch took some effort it ran great and starts right back up when hot so here's what i changed
- fuel filter
-spark plugs
- rotor
-distributor cap
-spark plug wires
still no luck so i brought it to my mechanic he found out that there was too much presser in the line so he changed the fuel pump regulator and still got the high pressure so he found out that the return line was sitting on the bottom of the tank so he fixed that witch corrected the pressure problem but still hard starting when cold
next he changed out the distributor witch was warn but still no luck and hes stumped so am i so he gave it back to me to drive it till it craps out so he can figure out whats wrong
so i am looking for any help anyone can offer thanks also i was told it might be the map sensor so that's what I'm changing out next
wayfastwhitey44 is offline
post #2 of 8 Old 09-26-2007, 08:04 PM
FlSpearhunter
2005 WK
What kind of vehicle are we talking about? What year? What engine?
OOps, missed it in the first line sorry...how does it run once it does start? Idle rough, or does it run ok?
2005 Liberty Limited 3.7
2005 Grand Cherokee Limited 4.7
FlSpearhunter is offline
post #3 of 8 Old 09-26-2007, 08:13 PM Thread Starter
wayfastwhitey44
um its ruff for like 2 seconds right after it gets going then the high idle takes over it high idles fine then is lowers and idles fine
post #4 of 8 Old 09-26-2007, 08:44 PM
FlSpearhunter
2005 WK
Sounds like it could be the TPS or maybe the fuel system is leaking down while it sits...it's hard to diagnose when you can't see the thing let alone run checks on it. Search the board and maybe you'll find that someone has had the same problem and how they fixed it. Or maybe someone will chime in with more ideas...
Just a thought, but have you tried running a fuel system cleaner through it...possibly dirty injectors...I guess if that was the case it would run rough all the time tho...
post #5 of 8 Old 09-27-2007, 12:21 PM Thread Starter
wayfastwhitey44
yeah i put gum out injector cleaner in the tank i dont think it really did anything the colder it go in the mornings the harder it was to start
post #6 of 8 Old 09-27-2007, 01:28 PM
flame0086
Wrong oil wieght It would never hurt to change the oil and make sure you've got the right stuff in there.
100 mpg!! Western Washington Univeristy X-Prize Team
Support Search and Rescue
Get Lost
flame0086 is offline
post #7 of 8 Old 09-27-2007, 03:20 PM
versoel
2009 JK Wrangler
what oil do you run? i run 5w30 mobil one pure synthetic with the lucus synthetic additive.
i had over 205k miles on my last engine that i ran that with. other than when i submerged the block without a snorkel it ran great!!!!
versoel is offline
post #8 of 8 Old 09-29-2007, 12:27 PM Thread Starter
wayfastwhitey44
update: pretty shure its an electriacal problem. now as far as i know the engine check light comes on when you turn the ignition on but now when i turn it on and the light does not come on it does not start and when it does it starts any body got any ideas thanks
Im a newb. 1krzy1 TJ Wrangler Technical Forum 2 11-07-2008 05:54 PM
Another Newb ? ADub07 TJ Wrangler Technical Forum 12 06-25-2007 08:35 AM
Newb here auwrestler197 TJ Wrangler Technical Forum 5 04-03-2007 10:34 AM
Newb help! Bareass TJ Wrangler Technical Forum 10 06-15-2006 11:34 PM
NEWB! new help.. please? Winman517 YJ Wrangler Technical Forum 12 01-30-2005 06:33 AM
