New to YJ's What is this noise? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > New to YJ's What is this noise?
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 09-12-2001, 06:41 AM   #1
HJ
There is a double tube (Green & Black plastic each about 4mm diameter)hanging into the footwell adjacent to the heater unit which is sucking air and makes a hissing noise.
Can someone tell me what this is or where it should be attached?
Best wishes - Hwfa
Hwfa.jones@wmc.ac.uk
Hwfa
HJ is offline   Reply With Quote Quick reply to this message
Unread 09-12-2001, 08:38 PM   #2
Nightclaw
Sounds like vacuum hoses, but there aren't any vacuum-operated accessories in the passenger area... Very odd - now I'm wondering what it could be. Anyone?
[b]'94 YJ Sahara Hardtop[/b]
4.0L / AX-15 / Stock NP231 / Stock D30 (open) / D60 (35-spline, Detroit locker, Moser axles) / rear disc brakes / 4.56 gears / Advanced Adapters SYE & CV Shaft / 33" BFG MT-KM's / Thorley Header / Magnaflow Muffler / BesTop Flares
Nightclaw is offline   Reply With Quote Quick reply to this message
Unread 09-12-2001, 10:17 PM   #3
JeeperBill88
There are green and black vacuum lines that go to the vacuum motor on the front axle to slide the internal collar to engage the axles when in 4WD. Check the top of the axle on the passenger side for two open vacuum ports on the round case of the vacuum motor... When you move the transfer case into 4WD, does the "4WD" light come on in the indicator panel above the steering column?
Jeeper Bill
88 YJ, 4.2L, 5 Sp
2.5 In RE Lift
31" BFG AT KO's
JeeperBill88 is offline   Reply With Quote Quick reply to this message
Unread 09-13-2001, 03:55 AM   #4
HJ
Thanks for such speedy response - I have looked to see if the tubes connect to any obvious place, but must have missed something.I'll have another search
The 4WD light does come on when selected, although with a short, few second delay - it also stays on when de-selected for a similar period of time.
Thanks again folks
Hwfa
Unread 09-13-2001, 03:29 PM   #5
JeeperJay
My light does the same thing. Sometimes it takes a few seconds for the vacumn motor to engage the 4WD. As far as I know that is normal. But if the light does come on, then your vacumn system should be working fine.
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline   Reply With Quote Quick reply to this message
