new yj - JeepForum.com
post #1 of 13 Old 10-17-2013, 06:05 PM Thread Starter
urukabaar
new yj
Just got a new 95 yj has 4 inch shackle lift. Have never liked them and heard there dangerous. If I do a spring over will I have to have to get sye and longer drive shafts.
95 YJ 4inch lift on 35s /8.8 with 4.88s going in soon
urukabaar is offline
post #2 of 13 Old 10-17-2013, 06:47 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Youre a long ways away from doing a spring over if youre asking questions like that. If youre dead set on it, you should spend the next few hours reading about soa. Much more to it that moving the perches.
If I were you, id ditch the shackles(after you post a picture of your jeep and them lol) and add a spring lift appropriate to the size tired you want to run. Add a small shackle lift as well.
But yes, youll have to get those as well as many more parts.
Michaelgoesrawr is offline
post #3 of 13 Old 10-17-2013, 07:18 PM
YJ4LIFE
I had a 2 inch shackle lift. how long are your shackles??
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #4 of 13 Old 10-17-2013, 07:25 PM Thread Starter
urukabaar
The shackels are 6 inches giving 4 inches of lift was on it when got jeep. And have done spring over on sami but not jeep just wondering diff.
post #5 of 13 Old 10-17-2013, 07:32 PM
flcracker
Stock shackles are 4" long so you have a 1" shackle lift.....
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline
post #6 of 13 Old 10-17-2013, 07:46 PM
jimbos76cj
If the shackle are only 6" bolt to bolt then it's not a 4" lift shackle. For it to be a true 6" shackle lift it will be I've 16" long.
Stock ones are 4". A 1" lift shackle would be 6" long. Every 2" longer they are hole to hole the lift is one inch.
As far as the SOA goes I'm not sure how it works on a Sami but on a jeep if you do a SOA with out changing over to a high steer knuckle you will have an issue with components hitting each other and really bad bump steer
Here is my yj with 2.5" springs, .75" shackles and 1" body lift.
It's on a set of 35's right now. With a drop pitman arm I'm almost parallel and that's where they should be. If you look at the threads most people end up not liking those soa's due the steering problems. Now change over to a high steer knuckle and you can do it.
88 YJ 35's 8.8 rear, family style roll bar, ax-15 external slave conversion, Custom double D fab dash 4" of lift taurus fan, Head light wiring upgrade, MSD 6al, JB conversions SYE, 258 with RV cam, Long tube headers, Borla exhaust. 1"mm, Auto meter gauges.
jimbos76cj is offline
post #7 of 13 Old 10-17-2013, 08:10 PM Thread Starter
urukabaar
Yes you have to do high steer on sami to. My worry is the drive shafts being long enough so don't fall out if I flex it a bit. Not that florida has many rocks lol. And was just told was 4 in lift. The front shackles are 6inch and rear so guess its just inch lift. Means I need to find were my clearance for 35s come from? Hate to sound stupid but this first jeep. Normally run sami just couldn't pass up.
post #8 of 13 Old 10-17-2013, 09:43 PM
Michaelgoesrawr
Check for serial numbers on your springs as well as for a body lift.
post #9 of 13 Old 10-18-2013, 04:54 AM
jimbos76cj
Just north of Florida there's plenty of rocks. A 4" lift is right on the border line of needing a sye and cv joint. Post some pics of said jeep. A pic is worth a million inches.
post #10 of 13 Old 10-18-2013, 09:16 PM
Flajeeper1
1987 YJ Wrangler
Sure is a Purdy jeep Jimbo. I've got one that looks a lot like it.
Flajeeper1 is offline
post #11 of 13 Old 10-23-2013, 06:50 PM Thread Starter
urukabaar
Sorry took so long on pictures. 33 13.50s were on it now tires in truck are on it 35 12.50. The front shackles are my concern was told they gave 4 inches.
post #12 of 13 Old 10-23-2013, 07:08 PM
Michaelgoesrawr
Nah. Those arent 4" lift shackles. If they are only 6" from bolt hole to bolt hole, they are 1" lift shackles. They would be a foot long to give you 4" of lift.
post #13 of 13 Old 10-26-2013, 08:42 AM
jimbos76cj
Measure from bolt center to bolt center on your shackles. Subtract 4 then divide the remainder in half. That's how many inches of lift you got from your shackles. Ex 6" bolt to bolt = 1", 8" bolt to bolt" 2" etc etc.
