New YJ - Page 5 - JeepForum.com
post #61 of 74 Old 02-19-2012, 08:12 AM Thread Starter
JeepJon15
Hm... i am getting a wierd message trying to upload pictures. I'll see if i can figure it out.
JeepJon15 is offline
post #62 of 74 Old 02-19-2012, 08:34 AM
linusb
Dang you got a great deal!!! Well done!
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #63 of 74 Old 02-19-2012, 08:50 AM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
I think you scored a nicely condition lightly modded YJ for short money. You could never buy a YJ as nice as yours seems to be then mod it the same way for $5700.00. Enjoy!
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #64 of 74 Old 02-19-2012, 10:15 AM Thread Starter
JeepJon15
Thanks guys, i'm really happy with it. I'm still trying to get pictures up. I may have to wait till i get back to my computer.
It does have its quarks, but i say they give it personality. The drivers side full door handle doesnt work out the outside of the door, have yet to take it apart, maybe an easy fix. Gas guage is stuck on full. Those are the two main things ill be working on first.
post #65 of 74 Old 02-19-2012, 11:11 AM
G30SFF250
Sounds like a helluv a deal?
I would rather have a broke Jeep, than no Jeep at all.
G30SFF250 is offline
post #66 of 74 Old 02-19-2012, 03:03 PM Thread Starter
JeepJon15
New to me 94 yj sahara 4.0 5speed
Here she is!
post #67 of 74 Old 02-19-2012, 03:09 PM Thread Starter
JeepJon15
And if anyone is wondering. That switch on the ground in the last picture is a fuel pump switch.... thats right.
PO was having fuel pump issues. Finds out its a wiring problem that he cant track down. So he ran a new wire (kept old one in tact) and hooked up an on/off switch. Theft protection i guess. I thought it was funny.
post #68 of 74 Old 02-19-2012, 04:38 PM
G30SFF250
Looks great!
post #69 of 74 Old 02-19-2012, 05:09 PM
Ryno_XJ
Thats a set deal on that rig. Looks like you got a lot more bang for your buck then that 4 cylinder you posted up. I know you said you do not wheel much, but now you have a very capable yj if you ever decide to get into it. Which i highly recommend by the way! Lol
Ryno_XJ is offline
post #70 of 74 Old 02-19-2012, 05:38 PM Thread Starter
JeepJon15
Thanks guys!
And i'd like to try it out Ryno, it looks like a blast. Maybe i'll try some light wheeling, i cant afford for the rig to be down for any amount of time. I will eventually invest in a beater to get to work with. That way i can be a little more adventurous with her.
post #71 of 74 Old 02-19-2012, 05:55 PM
UnFocused
Excellent Jon! A really great piece of business.
Now is the time to do some diagnostics, most likely preventative but worthwhile at this point.
Pull the codes from the ECU, there's plenty of links on here if you don't already know how to do that. That will let you get ahead of the curve on any issues which are minor at this time but could become major.
I suggested earlier in this thread (and provided links) that you pull the plugs and check the engine with a vacuum gauge; now is the time to do those as well. It will take less than two hours in total and you'll have a really good understanding of what's happening under the hood.
However, considering the condition of your Jeep and it's enhancements I'd be willing to bet that everything is just fine.
You did GOOD!
UnFocused is offline
post #72 of 74 Old 02-20-2012, 04:31 PM Thread Starter
JeepJon15
Thanks Unfocused! I'll track down your post with the links. Glad that vacuum gauge i bought to tune my old carb wont be going to waste.
Anyone know the equation to find out your real miles traveled on 33" tires if the trip meter says around 140? Trying to figure out my mpg.
post #73 of 74 Old 02-20-2012, 07:18 PM
UnFocused
We don't know enough to be able to calculate actual mileage. The big unknowns are the gear ratio in the axles, actual tire diameter, and whether the PO already put a different speedo gear in the transfer case to adjust for tire size and gear ratio. But here's an easy way to do it, reasonably close, without knowing those things:
Bring up mapquest.com and enter a destination address about 25 miles away that you know to be dead on. Then select get directions; it will ask for your starting address. It will tell you to the 1/10th mile the distance. Drive the route (you can print it out) exactly as stated, return the same way, and do the math.
Believe it or not, several insurance companies use this to calculate distances between residences and fire stations in rural areas in order to calculate home insurance rates. So, it's pretty acurate. Plus you get to drive it
post #74 of 74 Old 02-21-2012, 07:24 AM Thread Starter
JeepJon15
Thanks, that seems like an easy enough method. Less math=good. PO said he "couldnt remember" if the speedo was calibrated for tire size. According to my gps though, the speedo reads about 5mph higher than i'm going (less if i'm doing under 35).
Also just asked PO about gearing. He said its 4:10 front and back.
Its funny. As i've been showing her off to friends and family, i've come to realize how impressive a winch is to people haha. I have to coax them away from it to show them my new JEEP.
2.4 , 4.0 , buying , YJ
