new welder - JeepForum.com
post #1 of 3 Old 04-19-2012, 08:22 AM Thread Starter
stumper
new welder
Hey folks just bought a Hobart 190 handler. Like all old New England jeeps body repair is a must, is there a big advantage using .023" wire over the .030" on the sheet metal? I have done a fare amount of heavier welding in the 1/4 to 1/2 " thickness but very little sheet metal work. Any input will help Thanks
stumper is offline
post #2 of 3 Old 04-19-2012, 10:11 AM
JeepAddOnsChris
Vendor
JeepAddOnsChris's Avatar
Yes, .023 takes less heat to melt it, thus the chances of burning through thin sheet metal is diminished and you get less distortion from warping.
We are currently away from the forums and unavailable for quotes. Please contact our sales team at 800-388-8637.
Visit our site
Like us on Facebook
JeepAddOnsChris is offline
post #3 of 3 Old 04-19-2012, 10:51 AM
mitchs1224
thinner is prob better ( less heat needed ) for body work. you shouldnt get as much warping or distortion in the areas around what your welding, its an art im still trying to get better at. and remember if your adding in pieces to spot weld constantly moving from on side and then back to the other kind of like tighning lug nuts so your heat isnt in one place very long..
mitchs1224 is offline
Would this Welder be Enough spawnofsatan YJ Wrangler Technical Forum 17 07-06-2011 10:36 AM
arc welder mylightsrsquare YJ Wrangler Technical Forum 26 11-09-2010 07:25 AM
this welder? white_elephant YJ Wrangler Technical Forum 21 01-23-2010 12:13 AM
Just got a welder! ufatbastehd YJ Wrangler Technical Forum 7 05-05-2008 06:44 AM
What welder to get? MasterD TJ Wrangler Technical Forum 4 05-03-2006 08:51 PM
