new(used) steering column to short?! - JeepForum.com
post #1 of 6 Old 05-20-2009, 11:27 PM Thread Starter
D.B. Cooper
I purchased a column off epay this winter to replace my stolen recovered 93 YJ tilt/manual. It is fitting to be too short. I am not grown up enough to have photo posting. The replacement is supposed to be a 92 wrangler manual/tilt and is exact except for the shaft is flush with the stamped column cap/bearing at the end. The shaft does not stick out at all past the bearing cap. All other shafts I have seen including my 95 and my 93 shaft sticks out 1 3/4" from the column end so..did I get shafted with the wrong shaft?what is this flush shaft column from?
I wish I had pic capability. I will e-mail pic if I have to.
D.B. Cooper is offline
post #2 of 6 Old 05-27-2009, 11:08 PM Thread Starter
D.B. Cooper
93 steering column replacement shaft too short.
O.K. does any one have a steering column where the steel shaft does not stick out 1 3/4" from the bearing/end cap/clip assembly?mine is a 93 and the eplacement (92?)I bought's shaft is flush with the end cap. what column is this?unless it was sawed off for removal which I don't see.
post #3 of 6 Old 05-28-2009, 05:18 AM
Burnerman
Burnerman's Avatar
The shaft end you speak of,, does the end that is flush on yours look the same as what should be sticking out? maybe the joint for the tilt mechanism is collapsed inside the column. IIRC when I replaced the lower bushing I had issues with the shaft end pushing up into the column. Did you try and pull the shaft out? If you post a picture to a free web host like Photobucket, Putfile or one of the thousand others, you can put the link on your post and then we can all see your dilemma.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #4 of 6 Old 05-31-2009, 08:45 PM Thread Starter
D.B. Cooper
shafted
yes burnerman thanks for answering. the shaft is identical excpet the notched/hard steel is flush with the lower shaft bearing instaed of 1 3/4" like all others. I have never heard of a tilt shaft collapsing upward toward the steering wheel but that does not sound good. I will try to get some host site pics thanks for sticking with me.
post #5 of 6 Old 05-31-2009, 09:22 PM Thread Starter
D.B. Cooper
yep
It was collapseded in. I pulled it out hopefully after a new bottom bearing all will be well. Thanks for the second brain. now onto the ignition switch.
post #6 of 6 Old 06-02-2009, 01:52 AM Thread Starter
D.B. Cooper
new used column install
Burnerman, I replaced the column and the replacement was pushing up into the column. the original 93 did not push up toward the steering wheel at all. it seemed solid. They are both tilt.otherwise identical Is my new used one o.k.? Its all bolted in now just don't want any chance of it receding up into the column. worried..Josh
Something in my steering column broke loose. I have no steering Swampwalker3 YJ Wrangler Technical Forum 5 11-06-2009 06:08 AM
Power Steering Fluid (Miniscule) Leak from Steering Column??? JRostron30 TJ Wrangler Technical Forum 3 07-09-2009 11:20 PM
New Steering Column fixed sloppy steering. Oman Jeep TJ Wrangler Technical Forum 5 09-23-2008 01:59 PM
electrical short in steering column? sulldoggy TJ Wrangler Technical Forum 1 09-06-2008 05:37 PM
Steering Column Telescope Too Short for BL? 8282feet TJ Wrangler Technical Forum 2 10-15-2005 11:11 AM
