new transmission going in... advice for transmission n00b? - JeepForum.com
post #1 of 6 Old 07-10-2007, 11:02 AM Thread Starter
VABYJ
going to richmond to buy a shiny new ax15 tonight... my old one was locked in 3rd, i couldn't get it to shift out of third... so my first question is, is it going to be retardadly hard to remove the old tranny since it's stuck in gear? thanks in advance!
VABYJ is offline
post #2 of 6 Old 07-10-2007, 11:09 AM
Ares
Ares's Avatar
Out of all the gears for it to be stuck in, you lucked out. 3rd is going to be about the easiest to get the tranny out with.
Aside from the normal PITA of removing a 4x4s tranny, nothing too hard. When i swapped trannys i had a friend come over and we pulled and reinstalled the transmission and t case as one unit. Was very heavy, and hard to move around. We used 2 jacks to help us install it. It actually went quick (maybe 10 minutes to get it mounted), but was a pita. You are supposed to seperate the tcase from the tranny on the vehicle, then install the tranny, then install the tcase. Do whichever you choose.
Have fun. Replace the clutch while your in there.
- Cameron
Ares is offline
post #3 of 6 Old 07-10-2007, 11:46 AM Thread Starter
VABYJ
the clutch is brand new, my cousin threw a centerforce at it two years ago, and the jeeps in storage when i'm in mass... i do know the slave is leaky though, and i'm praying that the tranny i'm getting is coming with one.
VABYJ is offline
post #4 of 6 Old 07-10-2007, 01:01 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
what year ax-15 are you getting, and what year is yours????? be carfull about going between pre94 to newer. slave internal to external.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #5 of 6 Old 07-10-2007, 03:03 PM Thread Starter
VABYJ
doesn't matter, it fell through... i'm begining to think that i'm just going to have to save up and do something more complicated and expensive... GAH
VABYJ is offline
post #6 of 6 Old 07-10-2007, 07:43 PM
jeepinMatt
jeepinMatt's Avatar
well when it comes time to to drop the old tranny and put the new one in. i used an engine hoist to help. take off the cover plate and then put the chain on the tranny and remove it. it also helps with lining up the splines.
jeepinMatt is offline
transmission advice needed. SEZARO21 YJ Wrangler Technical Forum 4 07-29-2008 08:30 PM
Transmission LOCKED UP! - Need Advice agood1 TJ Wrangler Technical Forum 25 05-13-2008 12:18 PM
Transmission Fubar'd? -- need advice ugmo YJ Wrangler Technical Forum 7 10-27-2007 04:28 PM
Transmission/TCase advice... Jesta YJ Wrangler Technical Forum 6 03-04-2005 09:50 AM
Looking for some transmission advice rrclimber YJ Wrangler Technical Forum 5 10-02-2003 04:27 AM
