New Transfer Case Skid Plate?? - JeepForum.com
post #1 of 31 Old 04-06-2008, 09:51 PM Thread Starter
Jeep Man 10
Ok...got my 2" BDS and 5/8" MORE Booms...looks great! (Will get pics later.)
Took it for a spin had some vibes and went to install tcase drop. The bolts holding this in were really rusted and the head broke off one. On another it actually looks like the plate has rusted around the bolt so that it isn't even doing anything!
So obviously I need a new skid plate. Are these easy to come by? I'll call tomorrow, but I'm hoping to get a used one and pop it with the tcd in there. If I can't find one does anyone know where I can purchase one online?
Long story short...I still got some work to do on the heap...I mean Jeep before its driveable.
Jeep Man 10 is offline
post #2 of 31 Old 04-06-2008, 09:52 PM Thread Starter
Jeep Man 10
By the way...the suspension/smoothness of ride was SOOOO nice compared to my sagging springs and stock shackles.
post #3 of 31 Old 04-06-2008, 10:20 PM
Stumedic
The skid plate is pretty heavy gauge steel. You sure it won't clean up with an angle grinder and a wire wheel?
'94 YJ 2.5L
'95 Grand Cherokee
2000 Cherokee Sport
Stumedic is offline
post #4 of 31 Old 04-06-2008, 11:22 PM
Opihi59
from here it gets rough
Opihi59's Avatar
The inverted cone shape of the skidplate around the bolts makes a perfect place for stuff like water, mud and salt to sit and eat through the plate. Mine was rusted in these areas so I sandblasted it and repainted with a rattle can. Used a lotta coats, was 3 1/2 cans overall. If one of your bolt holes rusted completely through, it is not a total loss. You can use a large/thick washer and a standard hex head bolt here--hardly worth trashing your entire skid plate. I have seen others have a hard time coming up with one. Several very gifted forum members have welded up their own plates from flat stock.
Post up your photos of your installed lift. I have the BDS 2" and 5/8 more shackles coming in the mail and hope to start the install before the end of April. I am certainly encouraged to hear that the ride is improved over your stock baseline. Presently mine has 2" lift shackles from PO and flat springs, and I'm really looking forward to the upgrades.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #5 of 31 Old 04-06-2008, 11:30 PM
Barrio
^ same here
hearing it rides better is good news im lifting mine within the month, but im not booming it gonna stay stock.
-OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap.
-Rio Red 1995 Ford Mustang- Daily Driver
Originally Posted by alfmoney
i see theres a bunch of toughguys on this forum or internet gangstas
Barrio is offline
post #6 of 31 Old 04-07-2008, 01:26 AM
Opihi59
Opihi59's Avatar
http://www.quadratec.com/products/16192_000.htm Quadratec has new versions, but they cost a lot. $363 and whatever it costs to ship to Montana.
http://www.offroadtoystore.com/Merch...ory_Code=33Eng This one is $380.
Then there's ebay $200 Buy it now in Oregon: http://cgi.ebay.com/ebaymotors/Jeep-...spagenameZWD1V
I believe a good heavy duty thick washer might run you like a buck. Good luck and submit some photos of your lift.
Opihi59 is offline
post #7 of 31 Old 04-07-2008, 01:28 AM
Opihi59
Opihi59's Avatar
Sorry, just noted the ebay one was for a TJ.
Opihi59 is offline
post #8 of 31 Old 04-07-2008, 11:27 AM Thread Starter
Jeep Man 10
Bump...I dunno. Anyone else have any thoughts on the washer for this? I don't want to drop my transfer case out on the trail? Surely with all the rusty YJ's out there someone else ran into this issue.
post #9 of 31 Old 04-07-2008, 11:47 AM
kingcn
Same Prob
Hey, I had the same issue with my skidplate. For the skidplate, I wire wheeled the whole thing and used por-15 on the whole thing. Where the bolt holes were rotted I used two 1/2in X 2in HEAVY DUTY washers over the hole. There is no way its pulling through.
For the frame I drilled out the two bolts that broke and had to cut a small hole in the frame to get a nut and washer in there.
Works great.
_____________________________________________
Front: Dana 30 4.10: Yukon Chrome-molly axles / Super Joints & Lock-Rite locker
Rear: Dana 35 4.10: Yukon Chrome-molly axles & Lock-Rite locker
C & C Fab Tube Fenders (giving these guys a plug because they treated me so well)
Home brew oil-pan/bell housing skid plate and gas tank skid plate.
kingcn is offline
post #10 of 31 Old 04-07-2008, 12:14 PM
yjcrawlr
You could always take your skid plate to a local welder an have them repair and beef your existing skid plate. My factory skid plate had enough oil leak on it over the years that it was rust free when I got my jeep. If It were mine I would weld some thick washers where the bolts go.
yjcrawlr is offline
post #11 of 31 Old 04-07-2008, 12:36 PM Thread Starter
Jeep Man 10
I guess I'm not fond of the idea of drilling holes in my frame...but...
post #12 of 31 Old 04-07-2008, 12:37 PM Thread Starter
Jeep Man 10
Did you fill these holes up afterwards on put a plug in them or something?
post #13 of 31 Old 04-07-2008, 03:25 PM
Stumedic
For what a new skid plate costs you can buy yourself a wirefeed welder and fix it yourself.
'94 YJ 2.5L
'95 Grand Cherokee
2000 Cherokee Sport
Stumedic is offline
post #14 of 31 Old 04-07-2008, 04:50 PM
giggityjeeper
I used washers for over a year now....2 of my were cracked and 2 other rusted bad, some big washer and new bolts and good to go till a replacement can be made. I do check them ever month or so for tightness and make sure they are holding up tho.
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #15 of 31 Old 04-07-2008, 07:10 PM Thread Starter
Jeep Man 10
Ok...so here is the before pic...
After pic...(will take better ones later).
[IMG]ttp://i296.photobucket.com/albums/mm196/jkal1010/100_1454.jpg[/IMG]
I'm getting a cold so I didn't take anymore. I'll post more later.
Here is a pic of my transfer case bolt.
The broken bolt...
Ok...so what is the verdict. Should I attempt repair of this or should I get a new skid plate and get it installed?
Transfer Case Skid Plate Billyjon1 TJ Wrangler Technical Forum 1 02-11-2009 03:01 PM
Skid Plate over transfer case RubiconsR4Grls2 TJ Wrangler Technical Forum 9 11-13-2007 11:22 AM
Transfer Case Skid Plate ntxjetta YJ Wrangler Technical Forum 6 02-13-2007 05:56 PM
Help can't get transfer case skid plate off patphish TJ Wrangler Technical Forum 20 10-16-2006 06:15 PM
transfer case skid plate 86comanche TJ Wrangler Technical Forum 7 04-12-2005 09:31 AM
