New Starter - JeepForum.com
post #1 of 5 Old 12-13-2011, 07:39 PM Thread Starter
Roeeg6
New Starter
I need to buy a replacement starter for my 1994 2.5L YJ. There are two options: a Bosch starter and a Mitsubishi starter, but I can't find out which one I need. I've looked online and can't tell the difference between the two. Has anyone else run into this problem?
Roeeg6 is offline
post #2 of 5 Old 12-14-2011, 04:00 AM
ptrcrynn
I just put a starter in my 93 . It was a Bosch, went to O Rielly's auto parts,bought a rebuilt for $75.00 lifetime warranty it says Bosch on the solenoid. Made in Mexico. Fitment was perfect,works fine. 20 minute fix. Not sure but the two starters are probably the same just different manf. Parts store should be able to give you the right one. Pat.
ptrcrynn is offline
post #3 of 5 Old 12-14-2011, 05:22 AM
grandboost98
my starter is on its way out so i took a look at it and when i wiped it off, there was a brand new bosch starter sticker on it. im guessing the po replaced it before it was sold but ive only had it for a year so ill be looking into other brands as well
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #4 of 5 Old 12-14-2011, 11:33 AM Thread Starter
Roeeg6
Thanks everyone I bought a Bosch starter today and it mounted just fine. Bought it Advanced for about $70
Roeeg6 is offline
post #5 of 5 Old 12-16-2011, 09:05 AM
planedog
Should have just changed the brushes in your Denso...
planedog is offline
starter , YJ
Starter Solenoid or Starter Motor Problems hjlueth0001 TJ Wrangler Technical Forum 4 10-20-2011 09:50 PM
Starter Relay or Starter Solenoid questions drespecki YJ Wrangler Technical Forum 7 01-22-2010 09:33 AM
Starter Problems(would TJ starter work?) Drastiq YJ Wrangler Technical Forum 2 10-14-2009 09:22 AM
whats the diffrence between a tj starter and a xj starter sameolsong TJ Wrangler Technical Forum 1 09-05-2009 09:08 AM
Starter or Starter Solenoid problem? Mike in IL TJ Wrangler Technical Forum 5 08-18-2007 11:35 PM
