new shackles - Page 2 - JeepForum.com
post #16 of 18 Old 03-05-2013, 08:30 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
On another thread recently they were talking about caster angle and shackles. I did some more research and math after that. I found that less caster is needed with larger tires, since the tire/road contact point is further ahead of the knuckle swivel. The OEM spec for my YJ is 6.3 (+/-1), which turns out to be about 5 needed for a 35" tire (compared to a stock 29" tire).
Doing the caster math as it applies to shackles, changing the shackle length by 3/4" changes the caster angle by 1. So, lengthening a shackle from the stock 4" means lowering the caster, which means for twitchier on-road handling and poorer on-road return-to-center (Jeep seems to have a mind of it's own). My present shackles are 5.75" long, and my caster is about 3.5 (had it measured by a shop), and the Jeep indeed has a mind of it's own on-road.
Actually, today's garage project is to fab up a new pair of front shackles that are maybe 4.5" long to get my caster much closer to the 5 I figure is good. I think it's worth a couple hours of shop time and 2' of steel to experiment.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #17 of 18 Old 03-05-2013, 09:11 AM
Andywear
4.5"lg with 3/8" bolt holes?
I guess Im asking what size dia. are the bolts?
wondering of how much meat will be needed around the edges
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #18 of 18 Old 03-05-2013, 09:32 AM
tom_sprecher
Most heavy duty aftermarket are 3/8" x 2" steel with 1/2" bolt holes and a 1" end radius.
Tom
tom_sprecher is offline
