New Revolvers Question - JeepForum.com
post #1 of 9 Old 05-10-2013, 07:46 PM Thread Starter
Rabbitsh
Some weeks ago i got a new set of teraflex revolvers, an hour after finish intalling i went to a trail to test it (and camp). Sadly in the first hard place i was the trans mount broke. I went back to the car service and replaced with a brand new mount, in the same place it broke again...
I didnt think it was becuse of the revolvers but some days ago i readed soething in a mexican forum about the broken mount because of the revolvers but didnt said how fix it to dont break mounts again.
I wonder if someone can tell me why it break a lot and how can i fix it.
The mechanic welded iron reforcements in the transmission mount, but i want to fix it so dont break with the time. I think is because the transmission moves a lot.
Rabbitsh is offline
post #2 of 9 Old 05-10-2013, 08:03 PM
GottaYJ
I broke mine without revolvers, but since I installed the revolvers have not had a single issue. I have the daystar poly mount.
1995 YJ Rio Grande 2.5L
GottaYJ is offline
post #3 of 9 Old 05-10-2013, 08:08 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Do you have enough slip in your driveshaft?
Luck Favours The Prepared
Anticanman is offline
post #4 of 9 Old 05-10-2013, 08:53 PM Thread Starter
Rabbitsh
In the front i know is enough shaft, in the rear i need add a little.
Rabbitsh is offline
post #5 of 9 Old 05-12-2013, 02:39 PM Thread Starter
Rabbitsh
bump
Rabbitsh is offline
post #6 of 9 Old 05-12-2013, 04:57 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
How are the motor mounts? How about the transmission torque arm?
post #7 of 9 Old 05-12-2013, 10:09 PM Thread Starter
Rabbitsh
The motor mounts are fine, i already checked tat, i dont know what u talking me about the torque arm. but that problem was after got the revolvers. Would you please explain me about the torque arm?
Rabbitsh is offline
post #8 of 9 Old 05-12-2013, 10:19 PM Thread Starter
Rabbitsh
i checked n internet about the torque arm, if is the little bolt that get tight the transmission to the trans skid plate, i think that one lost the nut, you think is for that?
Rabbitsh is offline
post #9 of 9 Old 05-12-2013, 10:37 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
With your transmission torque arm unhooked it can cause breakage of ujoints commonly but can cause stress to the transmission mount.
