New Radiator - Page 2 - JeepForum.com
post #16 of 19 Old 07-02-2011, 02:06 PM Thread Starter
CBinDC
Automatic or Manual Transmission, 2 ROW ALL METAL REPLACEMENT
Specifications
Core Size: 18-1/8 X 20 X 1-1/2
Inlet Header: 20 X 2-3/4
Outlet Header: 20 X 2-3/4
Inlet Connection: TOP 1-1/4 PASSENGERS SIDE
Outlet Connection: BOTTOM 1-1/2 DRIVERS SIDE
Transmission Oil Cooler: YES
Engine Oil Cooler: NONE
Mounting:
Notes: TWO ROW, ALL METAL
CBinDC is offline
post #17 of 19 Old 07-02-2011, 02:50 PM
imstillatwork
It should work. Those extra fittings are sealed up (or does the auto trans fluid go through a passage in there?? either way, it'll work). Looks just like the one I bought, but I cheaped out and got the plastic tanks.
imstillatwork is offline
post #18 of 19 Old 07-02-2011, 10:00 PM Thread Starter
CBinDC
I finished installing the radiator this afternoon. I had to drill some new holes in the upper portion to use the brackets. Filled it up with Coolant, let her run for 30 mins., and all's good.
CBinDC is offline
post #19 of 19 Old 07-02-2011, 11:05 PM
moonshinefuel
Good deal. I bought my all metal 3 row core back in about 2006..I think I paid 199.00 dollars and had a radiator shop get it for me from a local warehouse. Been worth every penny. Been running it just about everyday since that time.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
radiator leak. get the radiator fixed or replace? LiveAndLearn TJ Wrangler Technical Forum 32 11-24-2011 11:06 AM
Radiator Barn-Single row radiator freeskier93 TJ Wrangler Technical Forum 17 08-23-2010 02:35 PM
2 row aluminum radiator thats NOT from radiator barn LMG23 TJ Wrangler Technical Forum 3 03-16-2010 12:58 AM
Changed Radiator Cap. My Radiator EXPLODED blubaru2002 TJ Wrangler Technical Forum 8 08-11-2009 05:42 PM
Radiator Barn radiator rocks! Jim Shanks TJ Wrangler Technical Forum 10 12-08-2003 01:26 PM
