New motor; no spark or fuel pump - JeepForum.com
post #1 of 25 Old 02-20-2009, 04:06 PM Thread Starter
Checo18
Installed a new 2.5L motor out of a '97 in my YJ this week same exact motor everything bolted up the same. Has all the same wiring connectors. After we hooked everything up we noticed the engine light was on even with no key in the ignition, didn't think anything of it at first. After trying to start it engine had no spark at all and the fuel pump would not turn on. We have been completely baffled by all of this. None of the wiring was messed up or pinch in the swap it was an easy install with no other problems besides this.
Do you think this could be a computer or wiring problem we have no clue and need help, thanks
_______ Only in a YJ
/l ,[_____],
l---L -[]lllllll[]-
()_)-()_)--o-)_)
2.5L, 4" RE lift, 1" booms on the front, Revolvers on the back, 1" B.L., Aussie in the 35, 31" Trxus tires, Gen-rite rocker guards, BTF tube fenders, Pro Comp bumpers, KC lights, Hi-lift and a whole lot of love.
Checo18 is offline
post #2 of 25 Old 02-20-2009, 04:13 PM
Chris
Guy with jeep
Chris's Avatar
Are all your ground wires on and clean?
Chris is offline
post #3 of 25 Old 02-20-2009, 04:52 PM
Gonewhln
Try disconnecting the battery for 30 seconds then see what happends to the check engine light.
Also do you know how to pull your trouble codes if so check to see if anything comes up.
another thing did you remove the distrubtor from the new engine when you installed it ?
Gonewhln is offline
post #4 of 25 Old 02-20-2009, 05:41 PM
heep1991
easy test.. find fuel pump relay. take cover off relay. press metal flap down and see if fuel pump reacts. do same to starter relay. let us know what happens
1991 YJ 2.5L - SOLD
2006 Jeep Commander 6cyl - SOLD
2007 Jeep Unlimited Rubicon 3.8L
heep1991 is offline
post #5 of 25 Old 02-21-2009, 04:46 PM Thread Starter
Checo18
Yes and Yes Chris clean and tight.
/l ,[_____],
l---L -[]lllllll[]-
()_)-()_)--o-)_)
Checo18 is offline
post #6 of 25 Old 02-21-2009, 04:52 PM Thread Starter
Checo18
I know how to pull the codes, but it wasn't throwing any before we pulled the motor. But ill see if i get any thing it hasn't even ran yet.
Never pulled the distributor.
/l ,[_____],
l---L -[]lllllll[]-
()_)-()_)--o-)_)
Checo18 is offline
post #7 of 25 Old 02-21-2009, 04:53 PM Thread Starter
Checo18
This is just stumping the crap out of me.
/l ,[_____],
l---L -[]lllllll[]-
()_)-()_)--o-)_)
Checo18 is offline
post #8 of 25 Old 02-22-2009, 01:19 AM Thread Starter
Checo18
This is really starting to piss me off, the jeep is my daily driver and I need it to go to college any help would be gladly accepted thank you
/l ,[_____],
l---L -[]lllllll[]-
()_)-()_)--o-)_)
Checo18 is offline
post #9 of 25 Old 02-22-2009, 04:26 AM
dmock
1984 CJ8
Check the harness that goes from the battery area back and under to the tranfer case. This harness contains the neutral safety switch. Also the harness that runs through the firewall near the gas pedal. This harness has the fuel pump wiring. Good luck.
dmock is offline
post #10 of 25 Old 02-22-2009, 11:12 AM
Gonewhln
Did you find your starting problem ?
Gonewhln is offline
post #11 of 25 Old 02-22-2009, 11:41 PM Thread Starter
Checo18
Nope nothing yet
/l ,[_____],
l---L -[]lllllll[]-
()_)-()_)--o-)_)
Checo18 is offline
post #12 of 25 Old 02-23-2009, 06:09 AM
Que89YJ
Diagnostics
You said you had an engine light. What are the diagnostic codes?
Que89YJ is offline
post #13 of 25 Old 02-23-2009, 08:50 AM
idaholtby
Seeing how you swapped in an OBDII motor into an OBDI equipped jeep, I have a couple of questions on exactly what it is that you did. Did you swap all of the sensors and accessories from the old motor to new? Did you retain the original ECU and wiring? Did you swap over the fuel rail and injectors? Throttle body? The fact that the CEL light is lit even without the key in the ignition is worrisome. OBDII sensors run on a different voltage than OBDI style. The OBDII style TJ fuel rail does not have a fuel regulator and fuel return line as it is regulated at the fuel pump.
idaholtby is offline
post #14 of 25 Old 03-03-2009, 03:18 PM Thread Starter
Checo18
Sorry I got the years wrong it is an OBDI style, everything is exactly the same. CEL light was staying on with no key in the ignition because I had hooked the two wires that have one connector to the positive post of the starter solenoid and they should have been on the ground lug on the block, my bad. After fixing that the light turned off fuel pump is working now when key is in the on position or when you crank it. The thing now is that there's no spark at all.
Do you think those wires being wrongly connected could've fried the computer? Just got done checking codes and there is nothing wrong, the only codes are #12(battery disconnected), #33(A/C circuit open, note I don't have A/C), #55(End of codes). I'm thinking it could be that the CPS is bad, I don't think so cause it was running when we brought it into the garage.
Any more insight in this would be appreciated.
/l ,[_____],
l---L -[]lllllll[]-
()_)-()_)--o-)_)
Checo18 is offline
post #15 of 25 Old 03-03-2009, 04:41 PM
merlin7782
merlin7782's Avatar
Is the engine turning over at all now?
merlin7782 is offline
Replace Fuel Pump or Fuel Pump/Sending Unit assembly? Muratus TJ Wrangler Technical Forum 10 02-09-2012 09:08 AM
93 2.5 no spark or power to fuel pump fourgazim YJ Wrangler Technical Forum 2 07-05-2009 10:08 AM
Fuel pump assembly vs. fuel pump? eclipse27 TJ Wrangler Technical Forum 11 11-11-2008 09:18 AM
4.0L Motor Swap Fuel Pump Question shawnmiller75 YJ Wrangler Technical Forum 3 04-10-2006 04:45 PM
Electric Fuel Pump Issue, NOT pump 1995yj1978cj YJ Wrangler Technical Forum 4 05-28-2005 12:12 PM
