new to me 94 wrangler - JeepForum.com
post #1 of 12 Old 11-11-2013, 06:50 PM Thread Starter
mv7fd
just bought a 94 wrangler it has 165xxx miles on it with the 4.0 and 5 speed Manuel its in real good shape no rust runs great all the gauges work well sometimes when it idles the oil pressure gauge goes down but other than that great shape has a brand new best soft top and 33's and upgraded air condition the heater works on and off so i need to figure that out and the interior has been rhino lined so that makes it nice and it has that pull out thing to lock in the front end is there anything i need to look out for
mv7fd is offline
post #2 of 12 Old 11-12-2013, 11:02 AM
jred
If I recall, you need 8lbs of oil pressure for every 1000 rpm.
When the heat kicks out, does it stop blowing, or blow cold air?
jred is offline
post #3 of 12 Old 11-12-2013, 11:26 AM
jokerchief462
15-40 at idle, 40-75 at higher RPM from the FSM.
The only bad oil pressure is zero kind of like blood pressure
The heater may be cycling cold air as the thermostat opens and closes depends on out side temps and what you are doing. The OE stat is a 195 degree.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #4 of 12 Old 11-12-2013, 12:54 PM Thread Starter
mv7fd
It will blow and then sometimes it don't blow
mv7fd is offline
post #5 of 12 Old 11-13-2013, 11:13 AM
ashland82391
A lot like my girlfriend.....
ashland82391 is offline
post #6 of 12 Old 11-13-2013, 11:16 AM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Originally Posted by jred
If I recall, you need 8lbs of oil pressure for every 1000 rpm. When the heat kicks out, does it stop blowing, or blow cold air?
10lbs per 1000 rpm from what I've seen.
Michaelgoesrawr is offline
post #7 of 12 Old 11-13-2013, 12:29 PM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
Keep an eye on your wallet, these things will rob you blind!
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #8 of 12 Old 11-13-2013, 01:44 PM Thread Starter
mv7fd
i can imagine they will rob you blind so much you can do with them
mv7fd is offline
post #9 of 12 Old 11-14-2013, 03:54 PM
jeepguy85
1987 YJ Wrangler
Wait til you marry her. Then her blower motor is permanently disabled!
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
post #10 of 12 Old 11-15-2013, 05:56 AM Thread Starter
mv7fd
I was looking last night and the rear disk brake upgrade has already been done which is sweet
mv7fd is offline
post #11 of 12 Old 11-15-2013, 06:00 AM
ashland82391
You think they might have put an 8.8 under it?
post #12 of 12 Old 11-15-2013, 10:02 AM Thread Starter
mv7fd
That I don't know. Whoever owned it before the guy I bought it from new all the tricks to do to it it's all done right
mv7fd is offline
