new MC2100: no idle - Page 2 - JeepForum.com
post #16 of 27 Old 05-24-2012, 05:00 PM
superj
what is the choke setting at when its running? maybe its choking out?
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #17 of 27 Old 05-24-2012, 05:05 PM Thread Starter
orengutan
I've actually avoided touching the choke as much as possible. It IS supposed to be pre-set for me (it's a fully manual one). I've tried starting the jeep with the choke plate manually closed, tho, and got nothing.
orengutan is offline
post #18 of 27 Old 05-24-2012, 05:12 PM
MaddBones702
Have you used carb cleaner at the intake mounting of the adapter, throttle linkage of the carb, all the vacuum connections, including that hole? What have you done with the charcoal canister? Are all the different vacuum points on the intake manifold and exhaust manifold used or sufficiently blocked? Spray carb cleaner.
Lastly, keep in mind that there could be a problem with the carb!!!!!! I went through two carbs from the ebay guy before I gave up on what was a never ending battle with vacuum problems. First carb after one month of back and forth emails he sent a replacement. After problems with the second one he stopped responding to my emails. Got one from an econoline van with a 351 from car quest and its is perfect!!!!!!!
Who knew where this would go?
MaddBones702 is offline
post #19 of 27 Old 05-24-2012, 09:12 PM Thread Starter
orengutan
Seriously? The only reason I went with him is to have some kind of guarantee that I'm buying a functional item...
I've plugged everything everywhere that I can find. I plugged the urge signal to the canister but some of it needs to be left open to let it vent, no? Either way, the rest of the EGR (the CTO, the actual switch, etc, are all capped off completely).
I'm assuming the carb is functional because I HAVE had it running before I nuttered.
post #20 of 27 Old 05-24-2012, 09:41 PM
MTPKTS
Just wondering
Not giving the name of the guy, Did you get it from a guy from Colorado Springs, Co.? I have been trying to reach him because my carb was missing the electric choke. I have not had any luck reaching him.
MTPKTS is offline
post #21 of 27 Old 05-24-2012, 09:54 PM Thread Starter
orengutan
yeah, the same guy. The few times I've talked to him (via email) he's seemed very knowledgeable. I'm still operating on the assumption that its just my own fault here…
first thing tomorrow morning, I'm going to check on that damn canister (I don't believe its the problem but what do I know…) and all of the vac hoses again. I have to be missing something obvious. maybe I'll even de-nutter it… tho that doesn't really make any sense to me.
post #22 of 27 Old 05-25-2012, 06:53 AM
MTPKTS
posted
Keep us posted please, i have e-talked to him a couple times and cannot get any response from him now. i will be doing my swap next week and will let you know if i have the same issues. Good luck
MTPKTS is offline
post #23 of 27 Old 05-25-2012, 10:37 AM Thread Starter
orengutan
so what should the situation at the canister be, if I'm not using my EGR?
cap everything except to the fuel tank? I'm assuming there needs to be some sort of outlet left, right?
post #24 of 27 Old 06-19-2012, 07:04 PM Thread Starter
orengutan
followup: I was gone for a while travelling so I didn't have much time to work on this. however, I got some help on another thread here on statically timing the jeep with a protractor. I set the distributor to 20 degrees from TDC (which translates to 10 at the crank) and after a bit of harassment it started right up and held an idle. mildly irregular (next thing to figure outů) but its running!
thanks a lot for all the help guys!
post #25 of 27 Old 06-21-2012, 08:57 PM
evanjeep
2011 WK
Im looking at one on ebay the guy is from maine. One is electric choke for 270 and the other manual choke for 280
evanjeep is offline
post #26 of 27 Old 06-21-2012, 10:20 PM
MaddBones702
I'd go with electric choke. Easy to adjust and once set you don't have to do anything else.
post #27 of 27 Old 06-22-2012, 05:51 AM
evanjeep
2011 WK
Im thinking on it
evanjeep is offline
idle , mc2100
MC2100 Timing & Idle inniett YJ Wrangler Technical Forum 10 10-05-2009 06:28 PM
MC2100 Refuses to idle... lowsider YJ Wrangler Technical Forum 27 09-02-2009 07:17 PM
mc2100 idle problem Laredo22 YJ Wrangler Technical Forum 5 05-10-2009 11:13 AM
Mc2100 idle way to fast Saxist_tenor YJ Wrangler Technical Forum 6 03-08-2008 12:21 AM
MC2100 Idle leurinimj YJ Wrangler Technical Forum 4 05-22-2007 11:39 AM
