New to lifts, have some concerns. - Page 2 - JeepForum.com
post #16 of 27 Old 02-03-2013, 08:49 AM
dillonjm
2013 WK
That's probably most of your issue, those shackles are ridiculous and are screwing up you steering angles, namely caster.
In fact, standby, I see youre in Tucson. I may have some shackles in the garage.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #17 of 27 Old 02-03-2013, 08:57 AM
dillonjm
2013 WK
I have a pair of 1/2" booms you can have it you'd like. PM if you'd like to swing down and grab them.
Jerrod
dillonjm is offline
post #18 of 27 Old 02-03-2013, 08:58 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Very kind of you jerrod.
Luck Favours The Prepared
Anticanman is offline
post #19 of 27 Old 02-03-2013, 09:15 AM Thread Starter
rlloyd
You know I was wondering if they were a bit too long, it was a ***** lining up the front axle of the centering pins. Do the boomerangs allow for more flex? Sure ill take them if they help. Thanks man. That's awesome of you!
rlloyd is offline
post #20 of 27 Old 02-03-2013, 09:24 AM
jokerchief462
My booms were the answer to the stock shackles not cycling very well. Take it for a ride and flex it on each corner it might just level out.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #21 of 27 Old 02-03-2013, 09:57 AM Thread Starter
rlloyd
What do boomerang shackles do exactly?
rlloyd is offline
post #22 of 27 Old 02-03-2013, 10:01 AM
jeepyj13
Boomerang shackles are suppose to prevent shackle inversion. They also allow clearance of spring from rear crossmember when flexxed out.
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #23 of 27 Old 02-03-2013, 10:32 AM
flcracker
Get rid of those shackles.
^^^^ this
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline
post #24 of 27 Old 02-03-2013, 11:54 AM
Carlos14
Let us know when you get the booms in! That should get rid of this headache.
On to the next one!
Carlos14 is offline
post #25 of 27 Old 02-03-2013, 12:26 PM
Sycoglitch
They also help clear the front bumper too. And yea by the picture, the one side looks like its inverted in more than the other. IMHO I hate longer shackles. I'm currently running them on my XJ and can't wait until I have the funds to go full 4.5" leafs instead of 3" with shackles
01' Limited I6, C8.25, D30, NP231, 3" Zone AAL Lift, Extended Shackles and relocators, Hella H4 E-code headlights w/ HD Wiring Harness, Fully Swayless, Front JKS Disco'd when needed, 60mm Bored TB, IRO LCA, Rear Disc Conversion
Sycoglitch is offline
post #26 of 27 Old 02-03-2013, 01:06 PM
imstillatwork
Do stock shackles really have the linear travel required for a 4.5" lift spring to flatten out?
All I can imagine is that you will gain a stiffer spring to increase lift, with worse articulation due to stiffness and such a short swing in the stock shackle.
imstillatwork is offline
post #27 of 27 Old 02-03-2013, 01:26 PM
Sycoglitch
Extended shackles are good for aftermarket longer leaf springs, at least for my xj. Stock leafs are shorter and the extended shackle runs at 90*. This is my current set up to date. New stock style leafs, 3" zone AAL (since leafs were new I went with this for now), shackle relocator bracket and terraflex extended shackle. I get good flex out of them but my rear end is out of alignment especially running without a rear sway. At least with aftermarket leafs, the stiffness compensates for The lack of the sway bar.
And also, you can run smaller extended shackles to get flex and not stretch them so much
