New to lifts, have some concerns. - JeepForum.com
post #1 of 27 Old 02-02-2013, 10:48 PM Thread Starter
rlloyd
I just finished installing my 2.5 inch Rubicon Express lift, and have a few concerns. it looks like the left side of the vehicle is about 1 inch lower than the right side. Could this be due to improper alignment? Or could it also be that the front shackles are slightly angled inwards as well. Is this something that will settle with time, or with an alignment? There is no death wobble, that i can feel at about 35-40 miles an hour, does that occur at higher speeds? Where should i go for an alignment, the local auto repair, or should i take it somewhere like 4wheelparts?
rlloyd is offline
post #2 of 27 Old 02-02-2013, 11:06 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Wheel it. It'll fix itself.
Luck Favours The Prepared
Anticanman is offline
post #3 of 27 Old 02-02-2013, 11:17 PM Thread Starter
rlloyd
Really? I know the allignment is off, I'm definately going to get that done on Monday. but is there anything I should do to the steering components. I'm totally new the lifts, btw. I didn't touch anything of the steering components. Is there Anything I should do? I also have the sway and track bar off. Wanted to run sway bar discos but can't get the bolts that hold the links to the track bar in. The bushings keep it from seating in even with a hammer whack. Any type would be helpful.
rlloyd is offline
post #4 of 27 Old 02-02-2013, 11:50 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You may have to extend the drag link to straighten the steering wheel.
post #5 of 27 Old 02-02-2013, 11:53 PM
dillonjm
2013 WK
There are only two things you can do on a YJ for alignment, both can be done without an alignment rack.
Toe in can be set with a tape measure, and the steering wheel center can be done by eye.
That said, did you torque your suspension down properly and with weight on the suspension or with the Jeep in the air?
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #6 of 27 Old 02-03-2013, 06:09 AM Thread Starter
rlloyd
I hand tightened in air, and torqued in the ground.
rlloyd is offline
post #7 of 27 Old 02-03-2013, 07:01 AM
Rproject
1987 YJ Wrangler
What torque spec did you use?
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #8 of 27 Old 02-03-2013, 07:30 AM Thread Starter
rlloyd
75ft lbs on leaf springs, 45ft lbs on shackles and spring eye
rlloyd is offline
post #9 of 27 Old 02-03-2013, 07:32 AM Thread Starter
rlloyd
Woops, 75 on u bolts, and 45 on shackles and leaf spring bolts.
rlloyd is offline
post #10 of 27 Old 02-03-2013, 07:33 AM
Sycoglitch
Take pics and post. Let us see how it looks.
01' Limited I6, C8.25, D30, NP231, 3" Zone AAL Lift, Extended Shackles and relocators, Hella H4 E-code headlights w/ HD Wiring Harness, Fully Swayless, Front JKS Disco'd when needed, 60mm Bored TB, IRO LCA, Rear Disc Conversion
Sycoglitch is offline
post #11 of 27 Old 02-03-2013, 07:54 AM Thread Starter
rlloyd
Left side
Right side.
[ATTACH]556616[/ATTAC
On that left one, you can see the bushing insert as well. I do have the track bar and sway bar off.
rlloyd is offline
post #12 of 27 Old 02-03-2013, 08:10 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
What's the length on those shackles, cowboy? Methinks I found your steering problem and you're not telling us everything.
post #13 of 27 Old 02-03-2013, 08:23 AM
Sycoglitch
And if you can get us a side shot.
post #14 of 27 Old 02-03-2013, 08:46 AM Thread Starter
rlloyd
Well the shots I have are at night, after work. I'll get some better ones in the morning. Lemme show you what I do have. I'm not sure the length on the shackles. They were on The jeep when I got it. But they are at least 6 inches long.
There's a pic before wheels were on. What else you want to know?
rlloyd is offline
post #15 of 27 Old 02-03-2013, 08:49 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Get rid of those shackles.
