#46 | |
damn that top made it lock nice. Cant believe it fits. Try lighter fluid to get the stickers off i heard that works.
#47 |
Do just as Joe said. I usually like to cover the holes, so as not to get oil all over. A towel will suffice. Turn it over for a good minute allowing the oil to get where it has to go. Let it rest while you put the plugs in. Actually allowing the starter to cool. Check the oil and make note of what it looks like and the level of it. Keep the battery fully charged and the connections clean and secure. Check for fuel in the filter/carb. Look for any leaks fuel/oil/water. Attach the wires and go for it. Good luck
Ctskip For the decals use a hairdryer and a plastic scraper. Then use Goof Off to remove any residual |
#48 | |
I thought this was "impossible, because of the windshield angle!"....?Did i miss something? ![]()
Carry Concealed on Campus |
#49 |
That's what I thought too. I guess it's not true? I wonder how full hard doors would fit though.
Black '91 YJ, pretty much stock for now. Finished engine rebuild. Runs beautifully. |
#50 |
I was doin some lookin' and I realized that the inner winshield frame angles on TJ/YJ's are the same...it's the outer part of the frame on the TJ that's swept back more.
'95 YJ- 1.25" BL, 31" bfg's, black cragars, herc'd tub. sold '99 TJ Sport- 35's, 8.8, 4.88s, 5" RC LA, JB SS SYE, UFC TT, HD steering |
#51 | |
http://community.webshots.com/user/richmond1273 1995 Wrangler 4.0 AX15 NP231 D30 & 35 4.10 gears 3" Rough Country suspension 33x12.50 Mastercraft MT 2007 JK 3.8 42RLE Auto NV241 D30 & D44 4.10 gears |
#52 |
Definately crank w/out the plugs in. I would change the oil BEFORE actually trying to start it. Fire extinguisher nearby is handy...crazy things catch on fire when they sit and rot for a while!
US Army combat vet Armed Forces Jeeps Member #125 Red Jeep Club Member #251 In the Portland/Vancouver area? Check 'em out! Piston's Wild Motorsports Club Click here for 2.5L AX5 to AX15 swap |
#53 |
can we see some pics on how the TJ hardtop mounted to your YJ? when will you have some full hard doors to put on there. just wondering so we can clear this up. seems to have been a general agreement on the forum that it couldn't work.
#54 | |
Here's a pic. TJ hardtop, TJ upper hard sliders on a stock YJ- ![]() A TJ windshield tapers forward at the bottom which makes it appear to be a diff angle. My buddie and I swapped YJ/TJ doors once and the only thing that didnt line up was the striker.
jeepsurf endorses this post. Most of the time Admin, nightcrew.org 1990 2.5 YJ / 1997 2.5 TJ USAF VET |
#55 |
wow
Myth busted ![]()
#56 |
So when I tried to get the oil out, none of it did. I took the plugs out and turned the engine over alot. Is it possible that the oil seeped thru the gaps in the rings? Should I be worried? Should I just put the plugs in and give it a shot?
#57 |
Fire it up already!
#58 |
Ran outta time today. Wife had Dr's appt and I had to watch the baby. Looks like tomorrow. It wouldnt turn over by itself at first. I had to put a wrench on the crank, but then it turned just fine. I hope I didnt break a ring. We'll see.
#59 | |
I don't know how inclined you are with wrenches, but this might be a good time for a 4.0 or a 4.3...? I am half kidding, it should be fine if it is cranking over smoothly
#60 | |
Condensation builds up and you get a superficial (usually) rust ring just above the compression ring. After it spins with the wrench, shoot some more light oil in there and spin it again with the plugs out. Once the starter can spin it w/out "dragging", change the oil and fire it up. Again, I would NOT try to start it with that nasty old oil and filter. Change the oil and filter, start it, let it run till hot, and change it AGAIN.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
