Quantcast New Jersey SOA - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > New Jersey SOA
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
Old 06-09-2009, 12:34 PM   #1
DRauch
New Jersey SOA
Here in Jersey our laws really suck... I swear this state's run by Nazi's or something...
Anyway, max vehicle lift is 4".. Anything over that is required to undergo a stability test... Your truck falls off, it's on you. Sucks, doesn't it?
I'm just kind of curious if an SOA conversion will be counted as a lift or not... I'm not in the mood to have my YJ come crashing down.
Since the conversion can add between 5"-7" of lift, if counted as a lift it'd have to undergo a stability test.. Which I'm sure any SOA converted Jeep would fail.
Anyone have experience with this?
DRauch is offline   Reply With Quote
Old 06-09-2009, 12:38 PM   #2
CheapSunglasses
2007 XK Commander
Years ago my buddy did a SOA (here in NJ) on a Blazer and he needed to do the tilt test.
"The Bannana Channell, Programming With Appeal"....Stay Tuned For a Bunch More!
CheapSunglasses is offline   Reply With Quote
Old 06-09-2009, 12:43 PM   #3
doherty80
whats the other jeep laws in nj...lights doors fenders? i need to know lol
doherty80 is online now   Reply With Quote
Old 06-09-2009, 12:53 PM   #4
DRauch
The list begins...
Fenders:
Front fenders must extend over the full width of the tire tread. Rear tires that are not covered by the fender or other body parts must be equipped with metal protectors or flexible flaps that prevent dirt, debris and water from being thrown.
Lights:
Headlights shall be mounted no lower than 22" nor more than 54" above the ground.
Taillights shall be mounted no lower than 15" nor more than 72" above the ground.
Off road lights must be covered while operating on public roads.
Doors:
I've had experience with this one... Getting my Jeep inspected without doors was a pain in the ***. The first lady told me it was illegal and I've got to get doors on and return with them. Luckily, there was a guy working that actually knew the laws and told her no doors is legal and to proceed with the testing.
Old 06-09-2009, 12:58 PM   #5
HighFive
1981 CJ5
What if your Jeep is from another state? I live in Philadelphia and have a SOA with about 5-6 inch lift with 35's and i want to take it down the shore this weekend but don't want to be stopped.
[/color]
Let's go Flyer's!!!!!!
HighFive is offline   Reply With Quote
Old 06-09-2009, 01:53 PM   #6
DRauch
I'm pretty sure that won't be an issue as long as you modifications are legal in your state and you passed inspection. Seeing as you'll have PA plates, I don't think you'll get stopped.
Old 06-09-2009, 02:47 PM   #7
cmsurfer
I've been through the NJ highrise inspection without any issues 3 or 4 times now. Luckily enough, I never had to do a tip test. But I would imagine if your Jeep is setup right, there shouldn't be an issue. They can't go and try to tip it. I always go to the Winslow station.
And don't forget front AND rear mudflaps
cmsurfer is offline   Reply With Quote
Old 06-09-2009, 03:35 PM   #8
HighFive
1981 CJ5
Thanks man!
[/color]
Old 06-09-2009, 04:21 PM   #9
YJames90
aka Jamesx2
YJames90's Avatar
What does the tip test involve?
My 2.5 to 4.3 swap thread
http://www.jeepforum.com/forum/f12/4-3-swap-has-finally-begun-1237704/
If your going to talk about me talk to me
YJames90 is online now   Reply With Quote
Old 06-09-2009, 06:30 PM   #10
Robbypfd
I have been through the tilt test with 4 inch lift and 33s. They weigh your jeep as it sits flat and then you go on a 15 degree slope where your driver side 2 tires are on the slope and the passengers are on the flat. They then weigh how much weight is transferred to the passenger wheels and this determins if you pass. My son has a rubicon with 5 inches of lift and 35s and they said he just made it because it is heavier then my yj. Dont forget your flares must cover the tire tread and you need mud flaps that go down to the center of the wheels. A 15 degree slope isnt much,when you go offroading you hit much higher angled slopes then this.
Robbypfd is offline   Reply With Quote
Old 06-09-2009, 06:42 PM   #11
Burnerman
My brother in law called the station that does the tilt test. So far they've never had a vehicle roll but if you're the lucky one it's your dime. 30" from the bottom of the open door to the ground requires the "hi lift" sticker for a Jeep Wrangler. Yes, SOA is considered a lift. Anything above stock height is, be it body lift, ( light height here), suspension or tires. There is a maximun height in NJ also. They will turn you away at the lift test station if your vehicle is too high. CAn't remember what it was. PM floridajeepman, he's the one that called.
89' YJ Larado 4.0L,AX15
01' Grand Cherokee 4.0L
Check my Gallery for pics.
My Rebuild Thread
Take a minute and fill out your profile, Please
Burnerman is offline   Reply With Quote
Old 06-09-2009, 06:44 PM   #12
SteveJcoYJ
your not gonna roll over, honestly the stability test is like driving up a curb, i doubt anyones ever rolled on it
91ish YJ
Originally Posted by sportsdevil333 View Post
ive had girlfriends before and been laid numerous times I just didnt know how to go about with this particular situation since ive never seen a girl do what she did
SteveJcoYJ is offline   Reply With Quote
Old 06-10-2009, 12:11 PM   #13
doherty80
The list begins...
Fenders:
Lights:
Doors:
If i got the KC driving lights would those have to be covered? and if they were on would i get pulled over? and are any old fenders good or do i need to go for a certain brand so it lasts longer then a week
Old 06-10-2009, 12:19 PM   #14
1993redjeepyj
technicly you can not drive down nj streets with anykind of aux lighting on. unless DOT approved. the "tilt" test is hard for some vehicles. yes they drive you up on a slope but thats not it. they check your brake lines (need to have braided SS) you need mud flaps on exposed tire on rear, they cheak your steering radius compared to stock, and brake time compared to stock. they cheak all suspention parts to unsure they were put on prop. they cheak hights on everything, tails, headlight, and any off road lights (remember in Nj you can not have auz lighting mounted over 42 inch above stock head lights!!! wit our with out covers)
but going back yes SOA is a lift. the police officer i spoke to in Newton said for a jeep stock is 18 inch from flat ground to bottom of rocker. you are allowed 4 inch above that before needing a tip test.
1993 red jeep wrangler YJ, 2.5L, 5 Speed--- 4.5 inch RC lift, high lift jack, 31x10.50 general's, no back seat, Carr light bar wuth 4 lights, intake, 4.0 throttle body and spacer, high flow muffler, high flow cat, bed liner inside, HUGE stinger front bumper, 19 lb injectors, 1 1/4 shackles, Chrome hinges,CB with PA speaker and 4 foot wip anntena, Tera flex u bolt conversion, and rampage H4 headlight conversion.
1997 blue ford f150, 5.4L, auto--- work in progress
High Point Mudslingers
1993redjeepyj is offline   Reply With Quote
Old 06-10-2009, 12:41 PM   #15
cmsurfer
All aux lights need to be covered.
I'm not sure about being pulled over. I've driven pleny of times with my fog lights at night and never had any issues. Just make sure they are pointed down correctly.
As for the fenders, I've heard of people going through the inspection with a smaller set of tires (wont stick out as far), but they put the tire size on the 2nd windshield sticker along with the bumper and door heights. Any change to those numbers technically requires a re-inspection. Just make sure the flares completely cover the tire.
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
