new to jeeps - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > new to jeeps
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 02-27-2014, 08:43 PM   #16
Que89YJ
There is a guy near Armada that parts out Jeeps. He has a ton of used and new parts. Try him for anything you want to do and it will save you a ton of cash. His name is Chris. Tell him I sent you.
http://www.cfoffroad.com/
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 02-27-2014, 10:59 PM   #17
campyj
a bit of a drive for me for parts as im in the U.P.
will be ordering the auto pal headlights for the h4 conversion tomorrow and idk what bulbs to get for better light output
campyj is offline   Reply With Quote Quick reply to this message
Unread 02-28-2014, 04:57 AM   #18
Que89YJ
Not too bad. I know where your at. I go to Burt lake and to the up Fishing. You will find people going up state that willdrop parts for you. Join great lakes 4x4 too.
Unread 03-02-2014, 07:55 PM   #19
campyj
alright now I need a set or rear springs.. both bottom leafs on driver side cracked and fell off so its sagging a bit on that side so should I look for a used rear set of springs or get like a 1.5, 2 inch lift springs
Unread 03-02-2014, 08:11 PM   #20
Que89YJ
The springs need to match front and rear. You need to do them all. The 2" imo.
Unread 03-02-2014, 08:35 PM   #21
campyj
yea I was looking at a 2.5 kit but some say u gotta lower t case and might have other problems.. or just get 2 used rears and replace them
Unread 03-02-2014, 09:51 PM   #22
Que89YJ
2.5 is on the end of the range more because of the drive shaft. Most kits come with the tcase drop. That is easy. You can not replace just 2 so eliminate that option. If you are looking for good used springs try the guy I mentioned.
Unread 03-02-2014, 10:11 PM   #23
campyj
I meant like 2 used ones or a whole lift kit.. it has a 2 inch body lift when i looked at it today.. i was looking at the rough country 2.5 lift.. now as far as lowering the t case how do I do that
Unread 03-02-2014, 10:50 PM   #24
Que89YJ
It is a spacer added between the tscase mounting plate and the frame rail.
Unread 03-02-2014, 10:53 PM   #25
campyj
ahh ok.. I found some factory springs on ebay that are new for cheaper than lift springs so idk what I wanna do either get new factory springs or lift springs
Unread 03-03-2014, 02:09 AM   #26
RCwheelin
It all depends on what you see yourself doing with your jeep, if you have any inclination of taking your jeep off-road (which you would want to it's a jeep haha) you will certainly benefit a lot more from 2.5 inches of suspension lift than just stock springs and a body lift. Flex will greatly improve and what not. If you get stock springs but want to upgrade in the future than your just spending more money than you have to. Just my 2 cents
93' YJ
RCwheelin is offline   Reply With Quote Quick reply to this message
Unread 03-03-2014, 04:24 PM   #27
campyj
well we were planning on putting a plow on the front so idk if 2.5 springs would work with that
Unread 03-03-2014, 08:02 PM   #28
wb2510
My '94 YJ has a plow. I installed RE heavy duty springs with (greasable shackles) to help support the weight of the plow. It added 2.5" of lift. Stiff ride though with the plow removed but thats rare. Basically a winter plow jeep these days and works great!
2008 JK Wrangler Unlimited X
2005 KJ Liberty
1994 YJ
wb2510
Late Jeep Club #3
wb2510 is offline   Reply With Quote Quick reply to this message
Unread 03-03-2014, 09:19 PM   #29
campyj
I was looking at this lift kit.. if dad wants to lift the jeep
http://www.4wheelparts.com/Lift-Kits...FQ5gMgodwFkAsA
Unread 03-04-2014, 07:22 PM   #30
campyj
bump
