New to jeep stuff - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > New to jeep stuff
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 07-22-2007, 09:53 PM   #1
LoneWolf04
New to jeep stuff
Well, i recently purchased a dana 30 front axle out of a 93 YJ and while I was going through it I noticed the drivers side shaft has been changed as it has the large u-joint size in it and the passenger shaft has the small u-joint size in it. While replacing the joints I slid the drivers shaft back in and it seats properly, but when I tighten the axle nut it pulls the shaft out about 1/4" and the dust cover that is supposed to butt up against the tube opening is not where its supposed to be.
I've been reading and it sounds like the only dana 30s in the YJs that had the large u-joint size was ones equipped with ABS, or cherokees with ABS. There is no tone ring on the shaft so is this why the shaft is being pulled out when tightening it down? Is there a spacer or something made to put in place of the tone ring so I don't have to buy one? Any help would be appreciated.
Almost thinking of changing it back to the small u-joint and replacing the axle shaft seal on the side to do so. Thanks for any help.
LoneWolf04 is offline   Reply With Quote
Unread 07-22-2007, 10:41 PM   #2
Axl Jack
In 95 they went with bigger ujoints. You gotta watch. I went to replace mine, and when I went to the parts counter and asked for ujoints for a 94 without ABS.... they gave me the larger ones for a 95.
So it may not necessarily be the previous owners fault.
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline   Reply With Quote
Unread 07-22-2007, 11:53 PM   #3
flame0086
He's right. In 95 they had larger ujoints. However, I thought you could switch them with out any problems, am I wrong? I haven't notice a dust cover for my axle tubing, but I am still learning the more technical things about axles.
100 mpg!! Western Washington Univeristy X-Prize Team http://wwuxprize.blogspot.com/
Support Search and Rescue
Get Lost
flame0086 is offline   Reply With Quote
Unread 07-23-2007, 08:15 AM   #4
LoneWolf04
The dust cover is on the axle shaft itself, it pulls away from the axle tube opening when I tighten up the axle shaft nut. Either way the axle shaft is pulling out of the pumpkin on the drivers side and the passenger side doesnt pull out when i tighten it down
Unread 07-23-2007, 10:45 AM   #5
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
i run chromo axles so im no expert on a stock setup...., but i would check to see if the axle has a good contact with the differential.... if there is lots of contact, and the shaft is protuding slightly inside the carrier, then i'd say its fine.
the plastic cover is just that, a pos piece of plastic.....if you want good axle seals, get the aluminum ones.
another thing to consider is the axle disconnect....do you still have it? if so then the 2 axles arent gonna look exactly the same...
sounds like the guy broke the driver side axle (common) and went ahead and replaced it with either the 95 shafts, or a tj/xj shaft (which all have the bigger u joints)
try getting a used pair of tj shafts, and do away with the disconnect. least then you will know both are right, and only have to carry 1 spare u joint!
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee....
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover 4.6 HSE
2000 4.7 4WD WJ with a rebuilt motor.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
Years to gain the hands on experience, and offer it freely.
Minutes to gain the knowledge from the internet, and quote it just as freely.
Choose wisely!
leftlanetruckin is offline   Reply With Quote
Unread 07-23-2007, 10:55 AM   #6
kloppk
The larger u-joint axle is fine to run.
Heck it's stronger!
Just slide the plastic piece toward the axle tube after you have everything tightened down. (They can get bumped and move back and forth on the axle shaft)
kloppk is offline   Reply With Quote
