New here, thought Id show off my 95' build - JeepForum.com
post #1 of 57 Old 01-07-2010, 10:44 AM Thread Starter
aoudad
Bought this YJ at the end of Sept. for crawling around the TX hill country and in NM.
Ive replaced the cooling system, new Optima yellow top, Brown Dog MM, RE 2.5" lift with RE 5" greasable shackles, MT signature classicII wheels, 31"x10.5" MTR kevlars, Smitty XRC8 comp winch, Smitty SRC rear bumper, new rotors/pads, few things on the interior..... Next is a SYE for the TC and drive shaft.
aoudad is offline
post #2 of 57 Old 01-07-2010, 11:00 AM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
just so you know you dont need an sye and drive shaft on that small of a lift. nice yj btw!
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #3 of 57 Old 01-07-2010, 11:04 AM
Fhajad
I'd definitely save that money for the SYE for something else, definitely not needed.
Fhajad is offline
post #4 of 57 Old 01-07-2010, 11:07 AM Thread Starter
aoudad
Ok, thanks for the tip!
aoudad is offline
post #5 of 57 Old 01-07-2010, 12:19 PM
93jeepyj
Nice jeep man, that is super clean.
93jeepyj is offline
post #6 of 57 Old 01-07-2010, 01:59 PM
jsahara24
looking good!
99' Jeep Cherokee Sport
07' Toyota Matrix
jsahara24 is offline
post #7 of 57 Old 01-07-2010, 02:29 PM
southbound
Nice clean looking Sahara. It's really hard to find them in that good of condition. I plan on putting a build thread on here once I get the time to snap some pictures and really go into detail about some of the mods I've done. Keep the pics and mods coming .
I know everyone here is telling you to ditch the SYE plans, but I am behind you. The SYE will allow you to remove your t-case drop and pull the skid plate back up where it should be. I had some slight vibes after installing my 2.5", even with the 1" t-case drop. I went with a SYE and TW CV shaft and now everything is butter smooth. It's also just good maintenance, as the slip yoke is one of the weaker parts of the NP231. If you ever break a shaft you don't have to worry about the yoke sliding out an emptying you t-case fluid (making a bad situation worse). Doing the SYE is not a necessity in your situation, but probably a good idea. If you don't have any other more important projects to tackle, it's a good one to take on.
5.7L Hemi TJ Build: http://forum.aev-conversions.com/showthread.php?t=7434
southbound is offline
post #8 of 57 Old 01-07-2010, 02:32 PM
jeepinmichguy_
Soar Forever Six
I know everyone here is telling you to ditch the SYE plans, but I am behind you. The SYE will allow you to remove your t-case drop and pull the skid plate back up where it should be. I had some slight vibes after installing my 2.5", even with the 1" t-case drop. I went with a SYE and TW CV shaft and now everything is butter smooth. It's also just good maintenance, as the slip yoke is one of the weaker parts of the NP231. If you ever break a shaft you don't have to worry about the yoke sliding out an emptying you t-case fluid (making a bad situation just a little worse). Doing the SYE is not a necessity in your situation, but probably a good idea. If you don't have any other more important projects to tackle, it's a good one to take on.
i didnt have any vibes with a 2.5 in lift and no tcase drop. i had to do a tcase drop after the 4 in with no sye but thats all.
ΜΟΛΩΝ ΛΑΒΕ
post #9 of 57 Old 01-07-2010, 02:34 PM
southbound
Also, I have a question about your 31" tires. I am planning on purchasing a set of BFG 31x10.50 AT's when my 29's wear out some more.
Did you experience any significant loss in power or mpg's with the 31's? Your rig is pretty close to mine as far as mods go, so I'm curious to hear what, if any, issues you had relating to the move up to a 31x10.50 tire.
Thanks,
post #10 of 57 Old 01-07-2010, 02:46 PM
southbound
I think every Jeep is a little different from the experiences I've read on here. Some people need one, and some don't. If you don't have vibes, then it's probably not a big issue.
I went ahead and went with the SYE because I plan on keeping my Jeep for a long time and I was getting some slight vibes. I also like the fact that I went ahead and addressed one of the weak spots in my YJ's drive train. I'm planning on doing a 8.8 swap later on down the road to take care of the other weak link.
My Jeep is my DD and I figure getting a SYE is cheaper than fixing my undercarriage after a drive shaft flails around under there on the highway.
post #11 of 57 Old 01-07-2010, 02:51 PM
jeepinmichguy_
Soar Forever Six
you will have to get a new rear shaft or at least get yours cut down after a 8.8 swap. i ended up getting a whole noew one and this was about 6 months after the i did the sye.
ΜΟΛΩΝ ΛΑΒΕ
post #12 of 57 Old 01-07-2010, 03:04 PM Thread Starter
aoudad
Thanks,
Through 3rd its still fine, getting in 4th and 5th on the HWY, its noticable slower getting up to speed, but not too bad, I havent checked the MGP, did the lift on a full tank last Sat., so Ill check it in a week or so. I dont think I should loose more than 1-2 MPG. I had a 6" lift on a IH Scout II on 33's, so any MPG is going to be better than it was lol
aoudad is offline
post #13 of 57 Old 01-07-2010, 03:07 PM
r7069c
LOL. Look at all the tools everywhere! I can't wait to put my lift on. Nice clean garage by the way. I live in the Hill Country too. (Austin)
First Day Home
Three weeks later
Just waiting on the weather to paint and my income tax return to buy the lift.
r7069c is offline
post #14 of 57 Old 01-07-2010, 03:39 PM
southbound
It's kind of a given when you look at a D35 compared to an 8.8. I am planning on sending mine back to TW when I do swap in a 8.8. But the way things look now, it's probably not going to happen for couple of years, so it's no big deal.
Thanks for the info. That's kind of what I expected to be the case. I had an Isuzu Amigo that I lifted and put 32's on. It pretty much lost 5th gear and about 5 mpg's, so it doesn't sound like it will be that bad .
post #15 of 57 Old 01-07-2010, 03:56 PM
Billyjoebob007
[QUOTE=aoudad;8640824]Bought this YJ at the end of Sept. for crawling around the TX hill country and in NM.
Quote :
Looks good ! I wish i would have waited before i bought mine to get a Sahara .
Billyjoebob007 is offline
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 02:21 PM
Just a thought I had. Why J? YJ Wrangler Technical Forum 6 01-12-2006 01:55 PM
A little OT but I thought everyone would like to see this highmileTJ TJ Wrangler Technical Forum 1 05-18-2004 12:06 AM
Just a thought . glennv TJ Wrangler Technical Forum 5 02-12-2003 07:30 AM
