New Headgasket Overheating! - Page 2 - JeepForum.com
post #16 of 42 Old 11-11-2012, 01:11 PM Thread Starter
Nic
Fan clutch tested ok. Gonna replace water pump I think. Could a small coolant leak cause this overheating? My driveway is currently covered in coolant from the flush but it looks like a small amount may be leaking from somewhere.
Nic is offline
post #17 of 42 Old 11-12-2012, 11:43 AM
mike_breaker_5
a small leak should cause it to go slowly, not all at once. with a new-ish aluminum rad from a 2.5l tj in my jeep, i only have to run my fan if it's above 80* outside. also remember i am running a 5.2l in my yj. i am going to say that the rad is plenty ample sized to accommodate a small loss of coolant if your fan is running and working properly.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #18 of 42 Old 11-12-2012, 06:42 PM Thread Starter
Nic
Just replaced the water pump, still having the overheating issue. Perhaps the rad is clogged.
Nic is offline
post #19 of 42 Old 11-13-2012, 07:58 PM Thread Starter
Nic
Tried running the Jeep without the thermostat in it, it ran super cool, around 45*C. With out the tstat in it I could also see the coolant flowing through the radiator so I dont believe its clogged. I tested my tstat and its working fine. When I re installed it it came back round to the same problems. Gauge goes straight up to the red line. Also even after running the engine for a decent amount of time I cant see any flow in the radiator? Yet the tstat is working.. I guess the next step is to pressure test the system.
Nic is offline
post #20 of 42 Old 11-13-2012, 09:13 PM
jokerchief462
You have a blockage or a restriction somewhere in the cooling system. You can see if your heater core is a player by bypassing and running. If it goes away leave it bypassed until you can get a heater core. Just move the hose from the thermostat housing to the intake aand leave the heater core out of the loop. That will seperate the two systems and then there will be no doubt as to which system is blocked or has a restricted flow.
jokerchief462 is offline
post #21 of 42 Old 11-13-2012, 11:16 PM Thread Starter
Nic
Sorry I'm not quite familiar with this procedure. Disconnect the heater core hose (the one on top of the tstat housing) from the firewall and have to lead back into the water pump?
Nic is offline
post #22 of 42 Old 11-14-2012, 06:25 AM
jokerchief462
You have two hoses from the heater core one to the T=stat housing and one to the intake disconnect both and move to passenger side for flush of the heater core. You then take a hose from the t-stat housing to the intake which bypasses the heater core. Secure the heater core hoses and run. If no issues then heater core is blocked. If there is still a problem then engine block is blocked somewhere. While you have the heater core bypassed you can then jst flush the heater core with a garden hose to the heater core hoses.
post #23 of 42 Old 11-14-2012, 06:32 AM
mike_breaker_5
yup. doesn't really matter which heater core hose you disconnect from the core. all that matters is that the loop is made between the pump and the t-stat housing. similar to this here...
these pics may not look identical to your jeep but they will be similar.
post #24 of 42 Old 11-14-2012, 06:49 AM
Siva283
If it was working with the Thermostat out and then you put it back in it is most likely the thermostat. Is it in backwards? They are 4$ just replace it anyway maybe there is some one in a million scenario going on causing it to not work right under pressure. It also may not be opening all the way. All the coolant does not go through the heater core so even if it was blocked it should not cause this issue. When the engine is heating up if you turn the heat on is it hot. If so your heater core is working fine. You said when you squeeze the top hose it refills but slowly. I would be the thermostat is not opening all the way. Since when you take it out you get flow I doubt there is a blockage. I am betting on a malfuntioning thermostat. An easy way I found to burp the system is fill the over flow then fill the block through the thermostat housing and then fill through the top rad hose. Run the engine to operating temp with the cap off toping off the rad as neccasary. Keep the rad filled to the bottom of the hole for the cap and squeeze the top hose periodically while the engine is warming. Has worked several times without fail for me.
Ask me how I know...
Siva283 is offline
post #25 of 42 Old 11-14-2012, 06:54 AM
Siva283
Also check the timeing. I had a vehicle that ran great but the mechanical timing was off just a hair and it would cause the engine to overheat under load. It also happened after replacing a head gasket.
Siva283 is offline
post #26 of 42 Old 11-14-2012, 07:00 AM
mike_breaker_5
there's no way to adjust timing on the 4.0l. the pcm does it. if it's out of time then it has to be 180* out, even at that i think you can put the distributor in only one way. been a long time since i had a 4.0 distributor in my hands.
replacing the t-stat couldn't hurt as stated.
i'm not exactly sure why bypassing a plugged heater core helps but it usually does. it probably has something to do with increasing flow through the radiator.
post #27 of 42 Old 11-14-2012, 07:05 AM
Siva283
The PCM doesnt control Mechanical Timing. IEtiming belt streched or jumped a tooth.
Siva283 is offline
post #28 of 42 Old 11-14-2012, 07:29 AM
mike_breaker_5
the 4.0l doesn't have mechanical timing. like i said the pcm controls the timing in his jeep, you can't adjust it.
post #29 of 42 Old 11-14-2012, 07:30 AM
mike_breaker_5
stretched belt and a jumped tooth can happen. however a stretched belt can be compensated by the pcm (to a point). a jumped tooth will cause a lot more problems than just overheating in the 4.0l.
post #30 of 42 Old 11-14-2012, 07:36 AM
Siva283
He is having a somewhat strange problem. All the major things are working or atleast appear to be. I think it might be time to start thinking about and checking the more obscure things. I would still replace the t-stat first though. It is to cheap not too
Siva283 is offline
coolant , coolant flow , engine , head gasket , over heating
