new gears, new carrier? locker? - JeepForum.com
post #1 of 3 Old 10-23-2001, 05:06 AM Thread Starter
AJ
I have 3.73's in my stock d35 d30 and I'm getting ready to go to 4.56. Am I going to need a new carrier or any other parts to make the switch?
I'm going to install a rear locker when I do the gear change. I'm interested in a limited slip style for all around traction. I get about 6 months of snow and ice and want improved traction on it as well as my occaisional off road runs. Any suggestions?
AJ is offline
post #2 of 3 Old 10-23-2001, 08:15 PM
bob91yj
I'm not a big fan of limited slips, but lockers can be treacherous on ice. In your position I think I'd put the locker in the front axle for off road traction, keep the rear open or use a manual locker, ARB or OX.
Can't remember what the split is on carriers for sure, but if you get the OX or ARB it won't matter because either of those replaces the carrier.
Bob
91YJ Sahara, SOA, 4.88's, 35's, Locked
bob91yj is offline
post #3 of 3 Old 10-23-2001, 09:01 PM
jpwranglr9
i have a D35 with detroit locker with 4.56 disk brakes truss form a 95 YJ in MI. the split is up to 3.73 and 3.73 and up.
Its not what you buy...its what you BUILD!!!
1995 YJ ,SOA with 4" procomp front 3.5" BDS rear 1" shackle rear, custom stearing, 35x12.50x15 pro-comp MTs, warn xd9000i, on-board air from A/C, dana 44 rear and 30 front with 4.56, powertrax no-spin rear, custom disks rear/trutrac front, warn front shafts, HD SYE kit, HD front and rear driveshafts, Warn 4X flairs, PIAA 520 ligts and on and on and on :)
jpwranglr9 is offline
3.73 gears in a 3.07 carrier? ET48 TJ Wrangler Technical Forum 1 10-03-2008 11:44 AM
Carrier Gears on a D35 mrbigglesworth YJ Wrangler Technical Forum 3 07-16-2006 06:12 AM
New gears. new carrier? canuckyj YJ Wrangler Technical Forum 3 11-28-2005 05:46 PM
Carrier And Gears skp94yj YJ Wrangler Technical Forum 6 03-10-2005 09:09 PM
