New gears. new carrier? - JeepForum.com
post #1 of 4 Old 11-28-2005, 12:38 PM Thread Starter
canuckyj
This is my first post. My first forum.
I've owned my 94 Sahara for 2 years. This is my 2nd Jeep. Sold my mostly stock 83CJ a year before I bought this last one.
I just installed a 3.5 Black Diamond lift with optional Steering stabilizer and drop pitman arm. (Rouger riding than I expected)
The stock axles have 3.07 gears. I want to swap to 4.11s. Do I need to change the carrier for the gears? Is there a specific way I should go if I plan on somekind of locker for the rear?
I will be running my Michelin 235s for the canadian winter and I plan on 33x10.5 BFGMuds for the snowless months.
Any help is great
Thank you!
canuckyj is offline
post #2 of 4 Old 11-28-2005, 02:30 PM
jeffy
jeffy's Avatar
The carrier split is between 3.54 and 3.73's, I believe. If you want a locker that replaces the carrier then it's probably good to do it now rather then later. You won't have to pay extra labor since the carrier needs to come out anyway.
*** www.4BangerJP.com ***
jeffy is offline
post #3 of 4 Old 11-28-2005, 03:38 PM
93YJfalcon
I have the same lift. It will mellow out in a while. Grease your shackles, remove your swaybar and rear trackbar and flex it off-road for a while that will help them break in (and it's fun). Also check your rear shackles. Mine were hitting the aftermarket trailer hitch that I added on and weren't getting a full range of motion. Man you talk about bounce! That'll do it! I swapped up to boomerang shackles and now it is as smooth as a jeep can be.
ROCK OVER LONDON... ROCK ON CHICAGO!
93YJfalcon is offline
post #4 of 4 Old 11-28-2005, 04:46 PM
damon5150
carrier
hey man, you should be fine with the carier you have.but if you are going to re-gear hell get a locker if you can.just rember gotta change both!
95 yj, 2.5 5spd, 1 1/4 lift shackles, 30's, rep5000 winch, more goodies to come!
damon5150 is offline
new gears, mean new carrier? jcapodicapi TJ Wrangler Technical Forum 12 07-22-2009 08:46 PM
3.73 gears in a 3.07 carrier? ET48 TJ Wrangler Technical Forum 1 10-03-2008 10:44 AM
Carrier Gears on a D35 mrbigglesworth YJ Wrangler Technical Forum 3 07-16-2006 05:12 AM
Carrier And Gears skp94yj YJ Wrangler Technical Forum 6 03-10-2005 08:09 PM
