new gauge install questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > new gauge install questions
Dana 30 Truss for your TJ, LJ, ZJ, and XJFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread Yesterday, 08:27 PM   #1
welderman85
im about to start swapping gauges out of my 89 yj. im using four iequus gauges. temp,oil,volts.and fuel. the temp and oil are mechanical. I have a 12 pin connector on the back of the factory cluster. I also found a good diagram but the question I have is the gauge fuse, ground and illumination theres only one wire. Do I just jump the four wires together then tie it in to the one factory wire for these 3? thank you
welderman85 is offline   Reply With Quote
Unread Today, 03:51 AM   #2
timatoe
Trace out the sender line for each gauge, then yes there's one line for ground, +12v, and lights. This is what I did......
timatoe is offline   Reply With Quote
