new distributor help - JeepForum.com
post #1 of 9 Old 09-07-2013, 02:46 PM Thread Starter
jojojeep1
I needed a new dibtrib. but before I got threre first I put in a new icm, coil, plugs, wires, cap and rotor, and the timming chain is fairly new. so I put the #1 piston on tdc and the balancer on the 0 mark than I put the rotor on the # 1 on the cap, now it runs but bad, no back firing or that, just grapy, im stumped please help
jojojeep1 is offline
post #2 of 9 Old 09-07-2013, 02:53 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Did you time it after you put the distributor in?
Michaelgoesrawr is offline
post #3 of 9 Old 09-07-2013, 03:02 PM Thread Starter
jojojeep1
I can't it run's bad no matter where I put the distributor,
post #4 of 9 Old 09-07-2013, 04:42 PM
Old4X
1990 CJ7
It will not run right until properly timed.
Tell us how your engine is set up.
Carb?
Initial timing?
Vac source for vac advance?
Vac reading at idle?
Plug gap?
Nutter?
Centrifugal advance limiter plate set to 5, 7, 13 or 18 degrees?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 9 Old 09-07-2013, 07:20 PM Thread Starter
jojojeep1
2100 mc with nutter by pass, it was timed at 8 btdc vac advanced, plug gap 35
post #6 of 9 Old 09-07-2013, 07:24 PM
rocketboy
rocketboy's Avatar
Just to confirm simple things, you have the plug wires done correct? Sounds like you have everything right but you could have a few wires swapped?
___________________
1989 YJ - 4.0L
2001 WJ 4.0L
rocketboy is online now
post #7 of 9 Old 09-07-2013, 07:34 PM
Old4X
1990 CJ7
First thing to check, a very easy mistake to make,
Also, very easy to crack a plug or get bad plugs new out of the box.
Old4X is offline
post #8 of 9 Old 09-07-2013, 07:40 PM
Old4X
1990 CJ7
Also, these engines will run 180 out. Make sure you are TDC on #1 compression stroke
Old4X is offline
post #9 of 9 Old 09-08-2013, 06:35 PM Thread Starter
jojojeep1
thank you guys it was a bad dibstrib. they sold me
