new deck hook up problems - JeepForum.com
post #1 of 6 Old 04-17-2010, 08:49 PM Thread Starter
Chaos_Theory_Z
so i bought a new deck and tried to hook it up in my 89 yj connected the ground battery and ignition wires and connected it to see if powered up but it didn't. so i used a volt meter and tested the wires got 10-12v from the ignition wire to both other wires but then i got careless and let the ignition wire hit the metal of the dash it sparked and now i dont get any power from it and the tub door lights dont work
so i have a couple questions. 1. is there a certain fuse that i need to change for the ignition wire cause i looked at what i thought was all of them and none where blown 2. is there a reason it didn't work when it was getting power .
Chaos_Theory_Z is offline
post #2 of 6 Old 04-18-2010, 07:16 AM
johnoutdoors
Check the "IOD" fuse in the block in front of the battery.
johnoutdoors is offline
post #3 of 6 Old 04-18-2010, 10:18 AM Thread Starter
Chaos_Theory_Z
i dont have a fuse block infront of the battery just some relays to the side of it
post #4 of 6 Old 04-18-2010, 10:52 AM
timatoe
timatoe's Avatar
The fuse panel is under the dash on the firewall on the driver side.
timatoe is offline
post #5 of 6 Old 04-18-2010, 12:11 PM Thread Starter
Chaos_Theory_Z
ya i know that much i have looked at all fuses and replaced one that was blown for the dome light but the acc wire that goes to the radio still gives off no power.
post #6 of 6 Old 04-18-2010, 12:19 PM
timatoe
timatoe's Avatar
It helps to include the things you have done when asking a question if you don't want to get repeat suggestions.
Did you check the length of the line to make sure there's not an in line fuse? MANY times especially when a vehicle is 21 years old, there have been numerous modifications done, quite possibly there could be another fuse inline from a previous harness.
Did you check all of the fuses? The one for the dome light doesn't go to the radio, lot's of people actually just pull that one so they can run with no doors without the dome light being on.
timatoe is offline
Best Aftermarket deck? miked2905 JK Wrangler Technical Forum 4 12-04-2009 12:15 PM
Deck Cover? az07jk JK Wrangler Technical Forum 9 03-18-2007 11:05 PM
03 Deck in 97 console? truspincheemo TJ Wrangler Technical Forum 6 01-25-2007 01:52 PM
Rear Deck Covers stedwest TJ Wrangler Technical Forum 3 09-23-2006 07:37 AM
cd player hook up problems. Git-R-Done YJ Wrangler Technical Forum 8 08-03-2006 11:14 AM
