New Calif Smog Legal Carburetor for a YJ - JeepForum.com
post #1 of 6 Old 07-09-2009, 12:43 AM Thread Starter
abavetta
I have a pretty much stock 1990 Jeep Wrangler YJ with a 258 cu in inline 6 CY engine. I think the carburetor is a Carter 2 barrel design. I want to put on a new carburetor. So before you can say Weber I live in CA so it has to pass smog. I've looked online and at places like Summit Racing and can't find anything. Can anybody make a suggestion? I would appreciate it my car is hard to start and the choke sticks in the closed position and if I manage to start it by holding the choke open it doesn't run all that well and its only got 57,000 miles on it. Thanks in advance.
Andy
abavetta is offline
post #2 of 6 Old 07-09-2009, 05:09 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
The only thing that passes cali smog is another stock carter or a fuel injection swap( Howell or Mopar) costing a few grand by the time you are done.
rustywrangler is offline
post #3 of 6 Old 07-09-2009, 05:23 AM
Old4X
1990 CJ7
The Carter is a good carb, else it wouldn't have been OEM from Detroit for more than 40 years.
Like any other carb, they need regular servicing. There are more than 15 settings and adjustments that must be right on these carbs for them to function to specs. Get it right, and it will be trouble free. Get it wrong and the engine won't run or will run poorly.
Even a quality rebuilt carb needs to have all the settings checked. Rebuilding carbs is fast becoming a lost art, but it is still being done.
I try to buy every BBD I can find from owners that think they are junk, I have never bought one that had already had the (factory recommended) idle tube mod done. That tells me something about how quick some are to blame the "crappy Carter" for their problems.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #4 of 6 Old 07-09-2009, 11:59 AM
timatoe
timatoe's Avatar
Try cleaning out the venturi tubes. There is NO other carb that'll pass CA smog. If I kept the venuri's cleaned on mine it would run well, but if I made too many changes in elevation it wouldn't hardly run at all. I did and would suggest if you've got the money going with a Howell Fuel Injection kit.
timatoe is offline
post #5 of 6 Old 03-08-2014, 08:56 AM
acehatz
1982 CJ7
Hi get the Howell efi system.it is.Calif smog legal amd is c.a.r.b. certified it will cost you around 1200.00
But well worth it all the orig smog off your y.j goes away. The instruction are great and very easy to install
I did 2 installs . Well worth the money
acehatz is offline
post #6 of 6 Old 03-08-2014, 09:08 AM
jbolty
jbolty's Avatar
I'm guessing that he figured something out in the last 5 years.
But FWIW, I'm very happy with my Howell too.
jbolty is offline
Ca. smog legal Carb. kf6kgc YJ Wrangler Technical Forum 1 08-20-2007 10:49 PM
'04 CA smog legal? Terrain Twister TJ Wrangler Technical Forum 11 05-22-2007 01:42 PM
YJ fuel cell- smog legal??? Mjjeeps YJ Wrangler Technical Forum 4 11-16-2006 01:26 PM
1990 YJ 4.2 Conversion Calif. SMOG!! rcpeters YJ Wrangler Technical Forum 2 08-19-2004 10:15 AM
Anyone kone the differance between Calif. Emissions vs. Standard Emissions? Missin44 YJ Wrangler Technical Forum 2 04-26-2002 10:37 PM
