New brake calipers? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > New brake calipers?
Awesome Open box items at OPENBOXOFFROAD.COMIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep parts, deals and more at JeepHut.com
Unread 05-21-2013, 07:41 PM   #1
87laredo
1987 YJ Wrangler
New brake calipers?
Ok so I bought two new brake calipers from autozone and was curious to know if they are side specific and if so how do I tell? One has a green plug in the fluid hole and the other has a red one if that helps.
87laredo is offline   Reply With Quote Quick reply to this message
Unread 05-21-2013, 08:32 PM   #2
4.7stroker
They are side specific. The bleed nipple MUST be higher than the inlet on both sides.
Dwayne
4.7stroker is offline   Reply With Quote Quick reply to this message
Unread 05-22-2013, 06:49 PM   #3
87laredo
1987 YJ Wrangler
Thank you very much Dwayne and one other thing, it seem like a stupid question but to the larger brake pads go on the inside of the rotor?
Unread 05-23-2013, 06:23 AM   #4
Siva283
The pad with the clip that sticks out the back(goes into the caliper pistion) goes on the back
[QUOTE=Magnum;14117863] I gave the Jeep the required offering of $$, sweat, and blood, and everything works fine now. -- Jim[/QUOTE]
[QUOTE=ldso;16498409]. It started with a $200 axle, and a few thousand dollars later I was done :)[/QUOTE]
[QUOTE=Luuca;16122017]diagnose the real issue before you start going all Obama on it - spending mad cash you'll need for other important things.
Ask me how I know...[/QUOTE]
[QUOTE=Overhead;17658665]this is also my second set of RC springs this year. I'd rather spend the money again and get something that will last.[/QUOTE]
Siva283 is offline   Reply With Quote Quick reply to this message
Unread 05-23-2013, 01:40 PM   #5
Old4X
1990 CJ7
The metal part of the pad DOES NOT go against the rotor.
Have seen it done wrong at a Jeep dealership, no less.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline   Reply With Quote Quick reply to this message
Unread 05-23-2013, 01:50 PM   #6
Siva283
Never thought about it being done that way. I always figured the metal clips made it obvious. I dont think I would go to that dealer for anything ever.
Unread 05-23-2013, 01:57 PM   #7
Old4X
1990 CJ7
I don't work there any longer. I had nothing to do with the above mentioned mishap, though.
