New alternator and a puff of smoke. - JeepForum.com
post #1 of 9 Old 01-27-2012, 08:00 PM Thread Starter
Phantomprophet
'93 YJ 4.0 inline 6.
Last week my battery and alternator decided to gang up on me and quit at the same time.
I replaced the battery with an optima yellow top and got a standard replacement for the alternator.
I finished installing the alternator and started the Jeep up successfully.
I turned her off. Then tried to start it back up and there was no reaction aside from a small puff of smoke (I could not locate the origin).
Now I don't seem to get any power. It doesn't try to turn over and the headlights don't turn on.
Anyone got a clue?
Any help is appreciated.
Phantomprophet is offline
post #2 of 9 Old 01-27-2012, 08:05 PM
4.7stroker
I would look at the fuseable links just under the battery tray. There is a relay where quite a few wires come together.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 9 Old 01-27-2012, 08:21 PM Thread Starter
Phantomprophet
Thanks for the reply!
Do you mean the fuse box right next to the battery or do you mean there is something I should check below (under) the battery tray? I thought there was just empty space and some body support stuff under there.
If you mean the fuse box right next to the battery then yes, I already checked the fuses in there and they all seem to be fine.
post #4 of 9 Old 01-27-2012, 09:42 PM
titosgreen95yj
i believe theres 2 50 amp maxi fuses... i only know this because i shorted out my mine putting on an alternator .... hope its that easy for yea..... check your terminals are snugged down good...
titosgreen95yj is offline
post #5 of 9 Old 01-27-2012, 09:46 PM Thread Starter
Phantomprophet
Located where? In the fuse box by the battery? I looked in there and didn't see any blown fuses. In line somewhere? Is there some other place I should look?
post #6 of 9 Old 01-27-2012, 09:49 PM Thread Starter
Phantomprophet
The terminals on the battery or the Alternator? Both are snug. I was able to test the battery with the bad alternator still in place. I could start the Jeep but the voltage was really low when I turned on lights, stereo, etc.
The one time I got the Jeep to start with the new alternator the voltage looked good with the lights on so I thought I was in the clear. Turns out... not so much.
post #7 of 9 Old 01-28-2012, 05:54 AM
Mark05059
under the battery box there is (at least on mine) a connection with many fusible links. Its way to the bottom almost but under the battery box.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #8 of 9 Old 01-28-2012, 06:46 AM
TSEJEEPERS
He has a PDC, No fusuble links it uses maxi fuses.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #9 of 9 Old 01-28-2012, 01:32 PM
JWELK
If you don't have one, it is time to get a good 30 to 40 dollar voltmeter, jumper clip leads and a test light, you may also want to get a battery charger.
Start with the battery and work outward, PDC, alternator, starter. Check the black ground cables, when we say check, remove them, twist them to make certain they don't fall apart, clean until shiny and re-install. As nothing works, it is going to be simple, bad ground cable or bad battery to PDC. I'm guessing, but the "puff of smoke" was probably the last gasp from a defective cable, either red or black, but from the battery to PDC or battery to ground(s).
Just because the fuses "look" good doesn't mean they are good. As for the "puff" of smoke? Where did it come from, dashboard, ignition switch, engine compartment?
Regards,
Jim W
JWELK is offline
alternator , electrical , power , power loss , YJ
How much do you smoke? -Deepskyy- YJ Wrangler Technical Forum 8 10-15-2010 02:49 PM
Smoke tx-Skydiver JK Wrangler Technical Forum 16 09-29-2010 05:07 PM
Smoke!?!? GnccRider350 YJ Wrangler Technical Forum 7 11-27-2009 07:08 AM
Ratchet + alternator = Smoke NEastUnlmtd TJ Wrangler Technical Forum 15 01-04-2009 05:01 PM
Big puff of smoke POLBOSS TJ Wrangler Technical Forum 4 05-13-2006 11:14 AM
