New 350 Now What Tranny??? - Page 2 - JeepForum.com
post #16 of 21 Old 12-11-2009, 01:46 PM
jbolty
jbolty's Avatar
Originally Posted by CreepyCrawler95 View Post
you know tht 700r4 is going to be an auto rt?
I got this mixed up with another thread where the guy was looking fo an auto trans swap.
jbolty is offline
post #17 of 21 Old 12-11-2009, 01:48 PM
CreepyCrawler95
too bad they didnt make manual 700's though, would be nice
CreepyCrawler95 is offline
post #18 of 21 Old 02-23-2010, 02:13 PM Thread Starter
SignGuy321
1987 YJ Wrangler
This may be a dumb question but... Why do you have to change the output shafts on the 231c? I have a buddy that builds driveshafts, can't I just have him build new shafts????
SignGuy321 is offline
post #19 of 21 Old 02-23-2010, 02:23 PM
Jeepsr4me19
1976 CJ5
Output shaft is not the same as drive shaft...... Output shaft is located inside the transfer case
Jeepsr4me19 is offline
post #20 of 21 Old 02-23-2010, 02:42 PM
540i
The output shaft on a 231C is a lot longer than on a 231J, don't remember how much but it is longer. Add that to the already too short of distance between the pinon yoke and the TC output with a 231J and you are going to have major issues with u-joint angles. That is the main reason as I see it, other wise, yes use the chevy yoke and make a new driveshaft would be a good way to go if we had room.
540i is offline
post #21 of 21 Old 02-23-2010, 09:55 PM
Machine1582569
My vote is what cottonmouth has.
1993 Jeep Wrangler S 4" military wrap lift with 5/8" Shackle lift. 32x11.5x15
Machine1582569 is offline
How do I Remove Shifter from Tranny? Tranny Brace Question as well kgillette YJ Wrangler Technical Forum 17 09-12-2010 06:11 AM
will a NP231 J TC from a six speed XJ Tranny work for an AX-15 Tranny New2Jeepin TJ Wrangler Technical Forum 3 12-07-2009 04:36 PM
Over filled tranny fluid 2 weeks ago, Now tranny problems chaznad TJ Wrangler Technical Forum 1 03-30-2009 06:10 AM
Should I repair Tranny seal or replace Tranny? Yankee-Juliet YJ Wrangler Technical Forum 10 03-29-2009 04:41 PM
tranny mount to tranny bolt size? pic inside dream911tommy YJ Wrangler Technical Forum 4 05-30-2008 08:16 AM
