New 350 Now What Tranny??? - JeepForum.com
post #1 of 21 Old 12-09-2009, 04:21 PM Thread Starter
SignGuy321
1987 YJ Wrangler
My brother in law just gave me a 350 out of his stock car. Now I am looking for a tranny and transfer case. I have a TH350 but it's 2wd. I would like to have a manual. I am on somewhat of a budget (XMAS Time). What would be my best choice??
SignGuy321 is offline
post #2 of 21 Old 12-09-2009, 09:24 PM
CreepyCrawler95
drop a sm465 in it
CreepyCrawler95 is offline
post #3 of 21 Old 12-10-2009, 06:53 AM Thread Starter
SignGuy321
1987 YJ Wrangler
is there a transfer case to use w/o using an adapter?
post #4 of 21 Old 12-10-2009, 07:13 AM
Jeepsr4me19
1976 CJ5
Your transfer case may be one of 2, 207-231. But in 87 the spline count was the lower one so neither one is good. Your best bet would be to find a 87 up to 92ish S-10 truck blazer and take that trans and transfer case. The case is located on the right(driver) side too. But remember adding that much more power will require you to beef up the rest of the drive train.
Jeepsr4me19 is offline
post #5 of 21 Old 12-10-2009, 07:22 AM
CreepyCrawler95
you can get a sm465/205 i believe
post #6 of 21 Old 12-10-2009, 07:46 AM
DominicVan91
my buddy dropped in a nv4500 mated to a 231 for his 350
works just fine
DominicVan91 is offline
post #7 of 21 Old 12-10-2009, 09:44 AM
540i
works just fine
He said inexpencive, nv4500 is around $2K if you can find one, nv3500's are easier to find, chevy mid 90's 4.3 powered S-10's and Blazers and halfton trucks. I bought a 96 blazer for the drivetrain, was able to test it all before i pulled it and then parted what was left and ended up with a good drivetrain for a couple hundred bucks.
540i is offline
post #8 of 21 Old 12-10-2009, 09:53 AM
cottonmouth
Im running the sbc 350 with 700r4 to chevy 231 transfer (out of blazer) with jb conversion sye kit. Has done great for me so far. Been about 4 years now, cheapest solution/setup i found
You don't quit playing cause you grow old, you grow old cause you stop playing. PLAY HARD!
cottonmouth is offline
post #9 of 21 Old 12-10-2009, 10:05 AM
jbolty
jbolty's Avatar
700R4. There are lots of them around, they have overdrive, the older ones have no computer and it comes in a heavy duty version with a thicker case.
Look for one with a big "K" stamped into the bell housing for the truck version.
jbolty is offline
post #10 of 21 Old 12-11-2009, 09:39 AM Thread Starter
SignGuy321
1987 YJ Wrangler
What model number would it be for the S10 transmission and transfer case.
Thanks Alot
post #11 of 21 Old 12-11-2009, 09:54 AM
CreepyCrawler95
you know tht 700r4 is going to be an auto rt?
post #12 of 21 Old 12-11-2009, 10:27 AM
540i
the manual to look for in S-10s is the NV3500, it will come with a 231C transfercase, this comes behind the 4.3 engine, the 4 cylinder trucks use something else that you don't want. You can use the 231C transfercase by switching the output shafts with one from a jeep (231J)
540i is offline
post #13 of 21 Old 12-11-2009, 01:34 PM
CreepyCrawler95
is the 231J the 23 spline?
post #14 of 21 Old 12-11-2009, 01:37 PM
Jeepsr4me19
1976 CJ5
yeap. it is
post #15 of 21 Old 12-11-2009, 01:42 PM
CreepyCrawler95
and those are 6cyl models rt. ive got an option to do an ax15 swap with a matching tcase and it came out of a 99 tj and i dont remember what spline count the 4vs6 difference were but i think the 21 was for 4's and the 23 for 6's. either way i guess my slip yoke will replace either or so it wont matter
How do I Remove Shifter from Tranny? Tranny Brace Question as well kgillette YJ Wrangler Technical Forum 17 09-12-2010 06:11 AM
will a NP231 J TC from a six speed XJ Tranny work for an AX-15 Tranny New2Jeepin TJ Wrangler Technical Forum 3 12-07-2009 04:36 PM
Over filled tranny fluid 2 weeks ago, Now tranny problems chaznad TJ Wrangler Technical Forum 1 03-30-2009 06:10 AM
Should I repair Tranny seal or replace Tranny? Yankee-Juliet YJ Wrangler Technical Forum 10 03-29-2009 04:41 PM
tranny mount to tranny bolt size? pic inside dream911tommy YJ Wrangler Technical Forum 4 05-30-2008 08:16 AM
