Never trust your Jeep with Firestone!!! - JeepForum.com
post #1 of 13 Old 10-07-2002, 08:15 PM Thread Starter
WranglerYJ94
I just spent $600+ on new 31x10.50 and 15x8 chrome rims from Firestone. Got the mounted, balanced, the whole bit last Friday. I thought I was ready to roll, good to go. Been driving around for a week now, and today I was turning into my girlfriends neighborhood and i hear clunk clunk clunk boom boom etc... look at my LR tire and its wobbling all to hell. @#%^@#!!!!!!! I didnt have a deep enough socket to fit the lugnuts so I went to a service station a block away. I pulled in and he said "holy $#!T" Turns out NONE of my lugnuts were torqued down, but lucky for me only the LR actually came loose. I tightened them down at the station, lucky for me the studs didnt break off. I'm going up there tomorrow and telling him he is going to put new studs and lugnuts on all 4 corners. Basically put a long story short, NEVER GO TO FIRESTONE!!!!!!!!!!!!!!!!!!!!!!!!!!
'94 YJ
2" BDS
31s
Flowmaster exhaust
Lights
Lotsa 'stuff'
WranglerYJ94 is offline
post #2 of 13 Old 10-07-2002, 08:29 PM
thecarman
Isn't Firestone just the maker of the tires. If so it wouldn't be their fault if the lugnuts aren't torqued down. It could have been the guy that put them on forgot to, and it may have been YOUR fault as well because 30 miles after they are put on you are supposed to take it back to them and have them tighten the lugnuts down once and for all, because they have a tendency to come loose or something the first 30 miles. Happened to me as well. Wasn't their fault, I forgot to torque them down after 30 miles.
1994 Jeep Wrangler 2.5L (White)
thecarman is offline
post #3 of 13 Old 10-07-2002, 08:30 PM
St.LJustin
St.LJustin's Avatar
Not to doubt that they didn't torque the bolts but are you sure they didn't loosen themselves? When I got a flat, the lug nuts loosened themselves on the spare a couple days later and I had to tighten them again. I knew it was loose because I could hear it for the entire day. Was the loud bang right after the clunks or were you hearing the clunks before? I would imagine that if they didn't tighten them at the shop, you would notice it as soon as you pulled away.
Again, I'm not trying to doubt you but I have a close friend who works at Firestone I know for a fact that as standard procedure, they check all the lugs twice before lowering the vehicle because I've watched them do it and asked my friend about it.
Black 95 4.0 YJ, RE Extreme Duty 4.5" with 33x12.5 BFG MTs and Much Much More
Member #5 of the Black Jeep Club
St.LJustin is offline
post #4 of 13 Old 10-07-2002, 08:55 PM
RCHavok797
RCHavok797's Avatar
I had a similar thing happen to me. I was driving on the highway and I had to pull over because I heard this loud clunking sound from the rear. So when I got out to see what was wrong I finally noticed that the right rear passenger wheel had almost completely come off the studs. It was sitting on only a quarter of an inch left of studs with absolutely no lug nuts left on. You can probably guess I was a little rattled after that. No damage was done especially none to myself, thank God, but every month I check my lugs to make sure they are tightenned. I think what happenned was when we checked the brakes we just never tightened down that one wheel.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #5 of 13 Old 10-07-2002, 09:14 PM
AllanAlxndr
Firestones also have their own stores, well here in AZ they do...
***What do I know, I just cause Problems***
*'90 Wrangler*
*4 Banger*
*6" of lift, (4" suspension, 2" body)*
*33" ATs on Outlaw II's*
*Pioneer DEH3500/CD deck*
*1800WATT Amp w/ Custom Box*
*2 - 8" Rockford Fosgate HEs*
*Cobra 18WXSTII w/ 4' Firestik Antenna*
Member of
AllanAlxndr is offline
post #6 of 13 Old 10-07-2002, 09:15 PM Thread Starter
WranglerYJ94
Well I guess it should have been Firestone's responsibility to tell me, as a customer, to bring it back after 30 miles to check the lugnuts, which they failed to do. I used to work in service at a Toyota dealership and no one was ever told to make sure the customer comes back after 30 miles after a rotate, new tires, new wheels, etc. I do not have Firestone tires. I am talking about the Firestone service stations. Yes, I am blaming whoever worked on my Jeep because all my lugnuts were hand tight and the guy at Exxon that does tires for a living told me hes never seen anything like it. He told me "if i were you id be up there at 730am givin them hell!" I could have been killed! Anyways, I'm glad Im safe and all i need is new studs and lugs.
'94 YJ
2" BDS
31s
Flowmaster exhaust
Lights
Lotsa 'stuff'
post #7 of 13 Old 10-07-2002, 09:48 PM
St.LJustin
St.LJustin's Avatar
Re: .
Amen to that. Yeah, the lug nuts can come loose if they are tightened correctly but this rarely happens. I also have never heard of checking the lugs 30 miles after installation either. If it were me, I'd do the same thing you're going to do. Good luck.
post #8 of 13 Old 10-09-2002, 11:51 AM
chambers1517
firestone
I went to firestone to have my ac serviced. I thought I would let them change the oil and check the brakes while they had it. I have a ford 8.8 in the rear. After 6 hours I was told they couldn't add any freon because they couldn't get the valves loose and were afraid they would break. They said they would totally rebuild the rear brakes for 600 bucks. It seems you can't turn ford rear rotors ,too thin. They also said they would rebuild the emergency brake or it would fail. I said no thanks ,I paid 600 for the whole rearend. Basically I spent 70 bucks for an oil change. See ya firestone..
chambers1517 is offline
post #9 of 13 Old 10-09-2002, 12:06 PM
Mels95YJ
Mels95YJ's Avatar
Re: .
If they gave you any type of printout, you may want to look on that. When I bought my MT/R's from Wal-Mart, they didn't tell me to bring it back either, but when I was looking at the receipt, it said to bring it back after 50 miles. I don't think it has anything to do with the lugnuts, but something with rebalancing them. I've read something about having a break-in period. I'm not taking up for them, just saying they might've had it somewhere else. If not, then I don't know what to tell ya. Glad to see nobody was injured.
Mel
Jeep with stuff.
Mels95YJ is offline
post #10 of 13 Old 10-09-2002, 12:42 PM
GASPEDDLER
TWO GOOD RULES OF THUMB:
1. ALWAYS HITCH YOUR OWN TRAILER.
2. ALWAYS STAND BEHIND THE GUY TIGHTENING YOUR LUG NUTS.
GASPEDDLER is offline
post #11 of 13 Old 10-09-2002, 12:44 PM
RICK'S92TJ
I took my wife's Ranger to the Shell station here to have her tires rotated. They told me to bring it back after 50 miles to have the lug nuts rechecked. I asked why, they said with dissimilar metals that they could come lose. She had aluminum rims.
92 black yj, 2.5 l 4 banger, 3.5 inch BDS suspension lift, 2 inch body lift, 33X12.5 BFG AT's,
RICK'S92TJ is offline
post #12 of 13 Old 10-09-2002, 08:48 PM
Bob K
Bob K's Avatar
Yes. Lug nuts should be retorqued after a few dozen miles on alloy rims. The alloys are a much softer material than the lug nuts.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #13 of 13 Old 10-09-2002, 09:11 PM Thread Starter
WranglerYJ94
safe
Just took my Jeep into Firestone today. Gave the guy real hell and he apologized, but he said "on the lighter note we got satellite TV in the waiting room!" How ridiculous can you get? I mean come on, I was almost killed. He kept explaining to me what an impact wrench was and how it's used. I told him that I worked at a Toyota dealership over the summer in service doing tires and oil changes and I knew what it was since I used on every day. He was speechless. I also commented on how my supervisor would not let the engine be started until each lugnut was tightened with a torque wrench. He was also speechless here and said something like "well we use dependable air tools and have never had a problem." I said "well you've got a big one now, and your damn lucky im standing here telling you this or else you'd have a real problem!" Basically they are idiots, and they will NEVER on earth be allowed to touch my Jeep again. BTW- got new studs and lugs out of em!
Hoorayyyyy Jeeps!
John
'94 YJ
2" BDS
31s
Flowmaster exhaust
Lights
Lotsa 'stuff'
DW? Maybe...should I trust a dealership? ShinySideUp TJ Wrangler Technical Forum 11 07-15-2008 08:38 PM
Would you trust these? roundedge4lfe YJ Wrangler Technical Forum 10 11-27-2007 10:28 PM
Never trust a tire shop rexmundi TJ Wrangler Technical Forum 4 04-04-2006 09:33 AM
Never Trust the DEALER!! bills79jeep TJ Wrangler Technical Forum 2 03-18-2006 12:02 PM
Do you trust your roll bar? tunesoul TJ Wrangler Technical Forum 17 01-14-2005 06:31 PM
