Never thought id have to ask But... - JeepForum.com
post #1 of 9 Old 08-06-2013, 08:23 PM Thread Starter
Gage56
its getting to be about that time for me to get the motor and trans back in the jeep
If you have followed my build you know that i had to patch the frame where the skid plate mounts, i did not put and holes or nuts in because i refuse to reuse the stock skid and want to make my own trans X-member and then do a flat skid
Ok question one .... when i go to start the x-member do i want the drive line eg.. motor and trans to be as level as i can get it or is it safe to have it on a angle ?
Question two.... id like to have a FLAT Skid or is the t-case going to hang below the frame ?
Question Three ..... Id like to keep the pinion angle as low as i can what would you all do to get this combo of questions done
Sorry for the long post but i just want to make sure i do this right the first time
Thanks Guy's
1992 YJ
Gage56 is offline
post #2 of 9 Old 08-06-2013, 08:27 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The motor mount lift or trans drop don't do much to the shifting action but I had some minor annoying problems. The flat belly is all depending on what you wanna do with the jeep. Make a plan and stick with it. Accommodating it afterwards is just lost time, money and parts. But gained experience.
Luck Favours The Prepared
Anticanman is offline
post #3 of 9 Old 08-06-2013, 08:32 PM
flashy
I am sure you have seen my build.....the motor and tranny dont have to be completely level, hence the crossmemeber drop kits to lower the TC to help correct drivelines. The down side to this is that your motor mounts will wear out quicker.
Time and budget build...lots of pics::::
94 YJ slightly modified
00 WJ stock
flashy is offline
post #4 of 9 Old 08-06-2013, 09:07 PM Thread Starter
Gage56
Ok thanks
so then the plan is for me to keep the x-case up above the frame so i guess that would put the motor close to level
next i should add that i do have the 8.8 and sye BUT for right now just to get it up and running i am going to still use the stock d/s and d35
so to use them shim shim shim ??
1992 YJ
Gage56 is offline
post #5 of 9 Old 08-06-2013, 09:42 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Shim
post #6 of 9 Old 08-06-2013, 09:50 PM
bob6987
I did a belly tuck. i have a 1" body lift and 1" motor mount lift.
the transmission is about 2" about the plate using the stock mount.
Looking at it through the frame there is a slight drop towards the rear still.
1991 YJ, 4.0, 6" lift, 40" tires, full cage, dana44/ford 9, detroit locker, 5.38 gear
2012 JKU
bob6987 is offline
post #7 of 9 Old 08-06-2013, 10:23 PM
kjg26
kjg26's Avatar
Any issues with the tub? Which skid is that?
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #8 of 9 Old 08-06-2013, 10:29 PM Thread Starter
Gage56
Shim
OMG WTF
1992 YJ
Gage56 is offline
post #9 of 9 Old 08-07-2013, 08:05 AM
SoNova
Hey that is my sister, that is not nice.
SoNova is offline
