Never driven another YJ - tranny clanking - JeepForum.com
post #1 of 4 Old 01-01-2012, 04:35 PM Thread Starter
bryris
I've never driven another YJ than mine before or any other AX15 trannied vehicle. so have nothing to compare noise and feel to.
Basically, ever since I've owned the vehicle, it has had a few minor transmission idiosyncrasies. All in all it is a solid driving tranny and I have no complaints - just curious about this:
When in first gear, if I don't match the engine speed with the tranny speed just perfectly, it'll clunk. Its almost like there is driveline slack or something. In fact, if I am slowing down still in first like coming up to a rolling stop or to drive through a street side gutter or something, I've gotten in the habit of pushing in the clutch, then adding a bit of gas before releasing again to prevent the clunk. If I leave it in gear, as I pass through that "zero torque" zone between where the engine is powering the wheels or acting as an engine break, it'll clunk. Occasionally, I've had some old lady pull out in front of me in a parking lot situation and I have to slam on the breaks while still in gear in first (going slow) and it'll clank fairly badly if I don't time pedal usage just perfectly.
I hope I have described this enough.
It'll hardly ever do it in 2nd, but does in just the right conditions. 3rd, 4th, and 5th are just fine - probably the higher gear ratio masks it, not sure.
Tranny is smooth otherwise, strong, never falls out of gear, no strange noises, smooth shifting all in all.
1995 YJ Sahara
bryris is offline
post #2 of 4 Old 01-01-2012, 05:26 PM
dillonjm
2013 WK
Check the transmission mount.
If that checks good, could be various other things, U-joint, slop in the rear pinion gear->ring gear mesh, loose u-bolts on the rear axle, a couple other things I can't think of right now.
I'm betting transmission mount though.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #3 of 4 Old 01-01-2012, 06:34 PM Thread Starter
bryris
Ive been reluctant to change the mount because Ive heard that those cross member bolts can be quite the nightmare. If they strip out, what then?
Also, to describe the situation a bit better, Ive gotten in the habit of pressing the clutch in really slowly when coming to a stop from first - like parking. if the rpm isnt matched just right, pushing in the clutch from first will often produce the clunk.
1995 YJ Sahara
bryris is offline
post #4 of 4 Old 01-01-2012, 07:11 PM
dillonjm
2013 WK
Sounds just like a tranny mount to me, but could be other things.
If they strip you gotta weld in new nuts or use nutzerts of some sort.
I'd get to checking on the transmission mount. If its not functioning properly it can cause the engine mounts to wear faster too.
dillonjm is offline
clanking? OffRoadHTC TJ Wrangler Technical Forum 3 03-03-2011 05:13 AM
clanking in 4x4 sburton1 TJ Wrangler Technical Forum 3 09-14-2010 03:58 PM
Clanking while in 4WD RedWrangler04 TJ Wrangler Technical Forum 2 02-21-2005 02:48 PM
Clanking/Clicking from tranny KGJeepTJ TJ Wrangler Technical Forum 4 07-08-2004 03:10 PM
clanking kjg26 TJ Wrangler Technical Forum 3 09-16-2003 03:35 PM
