Neutral safety switch/backup lights - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Neutral safety switch/backup lights
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSave 17.76% for the 4th of july with ruffstuff specialtiesJuly 4th Sale Event! and Yes, We're Open!
Unread 05-04-2015, 09:42 PM   #1
p1garcia
Hi, I've replaced my neutral safety switch on my 90 4.2l automatic after my backup lights stopped working. Trouble is now my backup lights also work while I'm 2nd gear and 1st gear. Anyone else had this problem before? I tried two different brand nss switches before getting an original mopar one. All switches have the same result.
I also replaced the harness for the switch but it didn't make a difference. I'm thinking it may be the comb lever inside the transmission pan that touches the switch. Anyone ever swapped this out? Where can I find more info for this?
Thanks,
Phill
p1garcia is offline   Reply With Quote Quick reply to this message
Unread 05-05-2015, 10:57 AM   #2
Que89YJ
http://www.jeepforum.com/forum/f12/n...roblem-355591/
Read the installation instructions carefully. I think its an installation issue. Its near the bottom of the thread.
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 05-05-2015, 06:45 PM   #3
p1garcia
Thank for the link. I read through the thread. The install instructions are for a different kind of nss than the one on mine. The switch in mine is the three prong style that attaches to a female plug. I can't find much info on installing this type of switch. It just threads on and plugs into the harness. I've tried installing it with all the different gears on. No go.
Unread 06-28-2015, 09:48 PM   #4
p1garcia
Update just in case anyone else has this problem. I ended up biting the bullet and taking my Jeep to a transmission shop. End result was the pan was removed and the internal gear selector comb switch had to be swapped out. Looks like the inside plastic piece that touches the nss sensor broke at the end where the drive, 2nd, and low gear would have pushed the sensor. This caused the backup light to turn on in gear.
