Neutral Safety Switch? - JeepForum.com
post #1 of 7 Old 04-19-2006, 12:46 PM Thread Starter
oh88fan
Is there a neutral safety switch on an AX-5 transmission? If there is, where would I find it?
oh88fan is offline
post #2 of 7 Old 04-19-2006, 01:02 PM
TellyDSP
Poland and PPV!!!!
I'm not sure if I'm talking about what you are, but I can start the tranny in any gear, and can start in neutral with my foot off the clutch. The only electronics I can think of that are on my AX5 is the reverse sensor.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #3 of 7 Old 04-19-2006, 01:10 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
yea ax5 has no safety switch of any sort
i like to start my heep in 1st gear with no clutch and instantly drive off.... fun!
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #4 of 7 Old 04-19-2006, 02:43 PM
acmeotally
i might be wrong but im pretty sure there is only nss on automatic trannys
acmeotally is offline
post #5 of 7 Old 04-20-2006, 12:59 AM Thread Starter
oh88fan
Thanks for the replys. The reason I am asking this is because I just replaced the tranny in my 90 YJ with a tranny from a 98. They are identical except that the old tranny has a switch that is located to the rear of the fill hole and the newer tranny does not. I was wondering what this switch was for? The back up light switch is in the same location on both, in front of the oil fill hole.
oh88fan is offline
post #6 of 7 Old 04-20-2006, 04:54 AM
Bobbywolf
Bobbywolf's Avatar
Not sure, but my 90 YJ, 4.2L with AX15 will turn over in any gear as well, no matter if the clutch is in or not lol. Likely not great for the starter, but it will pull you forwards.
Bobbywolf is offline
post #7 of 7 Old 04-20-2006, 07:06 AM
TSEJEEPERS
98 tranny is from a TJ? If it is then yes it probably does have a neutral saftey switch. I think they started with the TJs.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
Neutral Safety Switch Nuge TJ Wrangler Technical Forum 3 05-01-2009 07:10 AM
Where is my Neutral Safety Switch? xvincentx TJ Wrangler Technical Forum 4 12-05-2008 11:07 AM
AX% Neutral Safety Switch Canfourjeep YJ Wrangler Technical Forum 3 01-09-2008 01:39 PM
Neutral safety switch nolo263 YJ Wrangler Technical Forum 6 04-13-2007 11:41 AM
Neutral safety switch????? Jtwigg224 TJ Wrangler Technical Forum 2 04-11-2003 07:46 AM
