neutral safety switch? - JeepForum.com
post #1 of 8 Old 06-03-2011, 05:32 AM Thread Starter
95yj-af
I don't know if others are like this but my 95 rio grande doesn't have a nuetral safety switch. I was just wondering if all jeeps are like or if the p.o. removed it?
95yj-af is offline
post #2 of 8 Old 06-03-2011, 06:09 AM
dadstoy
Mine didn't have one. You could, and I did, start it in gear while on a hill, kept, me from rolling backwards.
dadstoy is offline
post #3 of 8 Old 06-03-2011, 06:18 AM
TSEJEEPERS
I do not think any of the YJs had one.
I think they started putting them in when the TJs started.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #4 of 8 Old 06-03-2011, 06:25 AM
ziebartrob
This.........I have a 91 and 93 and neither one has it.
Originally Posted by Mymmars
when your start to anthropomorphise your jeep into somthing above a dog and below a hooker
ziebartrob is offline
post #5 of 8 Old 06-03-2011, 07:13 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
^^^This^^^
YJs were never equipped with starter interrupt switches on the clutch pedals for manual shift models.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #6 of 8 Old 06-03-2011, 09:00 AM
Old4X
1990 CJ7
The neutral safety switch is the wingnut behind the wheel.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #7 of 8 Old 06-03-2011, 10:59 PM Thread Starter
95yj-af
Thanks for the help everyone. It just surprised me when I first got mine, jumped in and turn and it jumped forward almost hitting the car in the spot next to me. That is something I'm going to be checking in a more controlled environment from now on.
95yj-af is offline
post #8 of 8 Old 06-05-2011, 01:46 PM
JWELK
I have a 95, nada. I've gone through the electrical schematics and again nada. The airbags don't work either.
Regards,
Jim W
JWELK is offline
04 tj safety neutral switch dailydriven04 TJ Wrangler Technical Forum 10 08-09-2010 05:53 PM
Neutral Safety Switch kadgarth YJ Wrangler Technical Forum 4 02-27-2010 07:51 PM
Neutral Safety Switch Nuge TJ Wrangler Technical Forum 3 05-01-2009 06:10 AM
AX% Neutral Safety Switch Canfourjeep YJ Wrangler Technical Forum 3 01-09-2008 12:39 PM
Neutral safety switch nolo263 YJ Wrangler Technical Forum 6 04-13-2007 10:41 AM
