Negitive arch/spring inversion - JeepForum.com
post #1 of 16 Old 05-07-2010, 11:03 PM Thread Starter
91BoD
Negative arch/spring inversion
My stock springs are flat! I know this is common for stock yj springs, but to get any flex they go negative immediately. How bad is this for the spring? A lift is currently out of the question so what is my best option to ditch the shackle lift and stop going negitive? I've thought about waggy springs and doing a tiny stretch plus that extra lift. Although I've heard they bend really easy. The only other option I've heard is a bastard pack...
On to the pictures!:
Thoughts?
91BoD is offline
post #2 of 16 Old 05-07-2010, 11:11 PM
jpfix
other than sticking a crowbar in your wallet and getting new springs...there is not much to do. one option is to have your springs re-arched. given the time & fundage to do that, may as well buy springs
91 YJ Runs 79 CJ5 waiting for winter
YJ - one step away from a CJ = lots of interchangeable parts.
TJ - one step away from a JK = sudden urge to go to the mall
jpfix is offline
post #3 of 16 Old 05-07-2010, 11:19 PM Thread Starter
91BoD
Ooh just to make sure there no confusion. Those are flex shots. Otherwise they're flat in the front and very slightly arched in the rear. I'm hoping for some possible junkyard fixes considering I'm on a highschoolers budget.
91BoD is offline
post #4 of 16 Old 05-07-2010, 11:44 PM
jpfix
I missed the flex part - what are you going over?
jpfix is offline
post #5 of 16 Old 05-07-2010, 11:58 PM Thread Starter
91BoD
I'm on a little retaining wall in front of my house. Would have went up further but once I realised how bad they were inverted I decided not to push it.
91BoD is offline
post #6 of 16 Old 05-08-2010, 12:08 AM
jpfix
ah...I see, said the blind man
Looks like you have no issue and all is functioning as designed.
Make sure you have good bump stops in place to limit the negative flex
jpfix is offline
post #7 of 16 Old 05-08-2010, 01:46 AM Thread Starter
91BoD
Ok so a little bit of negative arch is fine?
Would going with smaller shackles instead of 8" ones my dad put on awhile back help? The front ones barely move.
Also, I'd still love a small lift. Any junk yard set ups decent? Wagoneer springs, bastard packs with s10 leafs, or the like?
91BoD is offline
post #8 of 16 Old 05-08-2010, 07:10 AM
Area.3.Fiftyone
Throw a set of AAL's (add a leafs) in there and be done with it if you want something on the cheap.
Or, go to the junkyard and pull a set of YJ springs. They sell them here all day long for $16 each.
Ditch those long a$$ shackles while you are at it.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #9 of 16 Old 05-08-2010, 12:50 PM
rpenczek
How about mow a few lawns or do a little baby sitting or muck some stalls or bail some hay and purchase a 2.5" RC kit, you can do it complete with shocks, stabilizer, new hardware and breaklines (if you need them) for under $700? Maybe less.
rpenczek is offline
post #10 of 16 Old 05-09-2010, 01:30 AM Thread Starter
91BoD
That's insulting... I just got home from working for 8hrs.. If I could buy a RE or BDS kit I would (not going RC might as well do it right or not do it at all) yes summer may bring more income, but I'm a do it yourselfer anyone can buy a kit and get it put on.. I like to put alittle blood into it to make it mine.. I'm also going to try and increase my weldig skills for future projects.
Yeah, I'd go with a custom pack before AALs. They just make it super stiff. That's why I was thinking waggy springs with a few things to minimize stretch (like an inch instead of the 2.5) and then correct my shackle angle.
Thoughts on this approach? Would I need a SYE with a 2" lift and 1" stretch?
And yes I want to ditch the shackles ASAP my dad added them about 4 years back along with what appear to be ranchero lift shocks. The tires would rub the flares when he got it and he took the quick and easy way out. Now it's my hell, wandering, pinion vibes, and just all around suckage.. ( I just recently did the tj flares need to get some signals)
91BoD is offline
post #11 of 16 Old 05-09-2010, 07:10 AM
Area.3.Fiftyone
You said you were on a "highschoolers" budget, hence the reason I recommended the AAL's or used YJ springs.
Adding Waggy springs will increase your wheelbase and give you some lift and is a good choice, but it's not within a "highschoolers" budget like you posted.
There is a lot more to adding them then just the used springs. You will also need to lengthen both driveshafts which will add to the overall cost.
I thought you wanted a cheap and easy fix according to your post?
post #12 of 16 Old 05-09-2010, 07:21 AM
Burns95
I am with "Iron Maiden". Lose the 8" shackles, throw on an AAL and do a 1" body lift. You wont get any cheaper than that.
Burns95 is offline
post #13 of 16 Old 05-09-2010, 01:06 PM Thread Starter
91BoD
Iron, don't get all butt hurt the first paragraph was not directed at you. I appriciate your thoughts and suggestions.
All I said about the AALs were i'd rather grab some used yjs and make my own pack. Afterall it's like having 4 different AAL kits to choose from and cheaper. (if I could find them for 16$ that's a steal!)
the only reason I mentioned waggy springs was I heard they are really flexy and soft. And I know there are ways to limit the stretch. Infact it could be adjustible from 0"-2.5". I agree this wouldn't be the cheapest or easiest thing in the world but I would probably keep it on alot longer then an AAL. So I will repeat and reform my question:
will I need an SYE and CV shaft with a 2" lift and 1" stretch?
Also is there any proprtion between 1" of lift and how much slip-yoke is lost?
I will do a 1"-1.25" body lift eventually as I would like to do a tummy tuck. but I would also like a diesel swap and money to fall from the sky... Haha
I understand I said highschoolers budget but that was so everyone wouldn't jump in with "buy a kit" alot. Of help that did. The point is I'd like to do something well that will last but cost can be a factor. Cheap and easy is far from what i want. That's how the 8" shackles got put on remember!?
Ooh and the longer I drive the closer a ujoint is to failing. Maybe if one fails I can get my dad to go in on some good springs?
91BoD is offline
post #14 of 16 Old 05-09-2010, 01:23 PM
MLJeeper
MLJeeper's Avatar
I love it when someone comes in to ask a question, someone throws out answers and then the op starts acting like were insulting them with answers he asked for. Fact is, butthurt or not, Iron maidens suggestion is probably the cheapest and most effective route on a "high schoolers" budget (short of just finding some yj springs in a JY to get you by). Cant help it if you dont hear what you wanted to hear.
And if a simple ujoint failure will get your dad to open his wallet for you, thats easy enough to arrange.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #15 of 16 Old 05-09-2010, 02:10 PM
fratis
fratis's Avatar
nothing wrong with a bit of negative arch particularly for a stock vehicle that sees very mild offroad usage. if its time to build great, if not take your time and collect the parts. theres many ways to go.
fratis is offline
arch , lift , spring , stretch , wagoneer
SOA spring inversion Fun2Jeep YJ Wrangler Technical Forum 0 10-24-2009 07:06 PM
lift spring arch????????????? rip_1986 YJ Wrangler Technical Forum 4 03-18-2009 02:54 PM
SOA spring question, no arch Justincredible YJ Wrangler Technical Forum 21 02-09-2009 11:38 PM
CJ Shackle inversion and YJ spring upgrade? finky YJ Wrangler Technical Forum 1 01-14-2004 04:41 PM
To Re-Arch or Re-Spring...? CanukYJ YJ Wrangler Technical Forum 12 09-25-2003 07:00 PM
