Needle zerks? - JeepForum.com
post #1 of 11 Old 09-12-2007, 07:14 PM Thread Starter
phoric
Needle zerks?
I have a 92 YJ and there are a few ujoints on my driveshafts that have needle zerk fittings on the ends of the ujoints. I do have a needle fitting for my grease gun but have been unable to get the grease to enter any of the ujoints.
There is a little ball in the needle fitting that I am just pressing on with the tip of the needle to get it to move inwards. When I insert the needle the grease immediately just comes right back out of the entrance hole. I've tried entering at an angle with the same results.
What is the trick to greasing ujoints with needle fittings?
phoric is offline
post #2 of 11 Old 09-12-2007, 07:42 PM
SWAMPRNR
The tip you need is pictured on the bottom right of the link
http://www2.northerntool.com/product-1/200303979.htm
A Big Hammer Can Fix Anything....
SWAMPRNR is offline
post #3 of 11 Old 09-12-2007, 07:58 PM
Burnerman
Burnerman's Avatar
It's tricky. My swaybar discos have them and it's tough. They may be clogged if you can't get it to go. I put a regular zerk fitting in and pumped them up the first time I greased them then after that the needle would work. You need to push the needle adapter super hard into the fitting while pumping in the grease.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #4 of 11 Old 09-12-2007, 10:28 PM
SWAMPED
Junior Member
yea im in the same boat as burnerman on my disconnects. just press hard and pump slow cause thats a lot of thick grease trying to go in a little bitty hole.
SWAMPED is offline
post #5 of 11 Old 09-13-2007, 03:28 PM Thread Starter
phoric
I guess I'll keep trying, I broke my needle adapter trying to push it in and have to go get a new one... I don't think they're clogged though, and it does the same with all 5-6 of them.
phoric is offline
post #6 of 11 Old 09-13-2007, 03:34 PM Thread Starter
phoric
SWAMPRNR, I don't know if the site is down right now or what, but I couldn't get to the link you posted... Do you have a part # or something?
phoric is offline
post #7 of 11 Old 09-15-2007, 11:11 AM Thread Starter
phoric
Well I went out and bought a couple different needle nose fittings for my grease gun and still cannot grease these things with any amount of effort... I think I'm going to say "forget it" and rebuild my drivelines with sealed, non greaseable u-joints. I could have done that by now with the amount of time I've spent on these stupid needle zerks.
phoric is offline
post #8 of 11 Old 09-15-2007, 11:50 AM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
are you sure they're needle fittings and not just low profile standard fittings?
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #9 of 11 Old 09-15-2007, 11:51 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
This sounds about right. I just did a few things on the jeep yesterday and one included a new u joint in the rear drive shaft. I thought it was a needle fitting but actually was a small reg fitting.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #10 of 11 Old 09-17-2007, 09:11 AM Thread Starter
phoric
Here is a pic of what they look like from the Stu-Offroad site. According to this page they are needle fittings.
phoric is offline
post #11 of 11 Old 09-17-2007, 08:09 PM
SWAMPRNR
Grainger part number is 6Y834
http://www.grainger.com/Grainger/wwg...earchIndexId=2
SWAMPRNR is offline
grease zerks? 03Wrangler TJ Wrangler Technical Forum 6 11-04-2007 02:05 PM
Got my MORE Boomerangs(Still press in zerks) learfxr YJ Wrangler Technical Forum 43 09-24-2007 10:36 AM
No Zerks... interesting gerrynjr JK Wrangler Technical Forum 3 06-25-2007 12:34 PM
leaking zerks.... gerrynjr TJ Wrangler Technical Forum 22 06-07-2007 02:06 PM
RE Control Arm Zerks - What other options MarkF TJ Wrangler Technical Forum 8 01-12-2006 01:36 PM
