Need you thoughts on Clutch Master Cylinder replacement - JeepForum.com
post #1 of 8 Old 05-19-2006, 02:14 PM Thread Starter
Johnny World
Johnny World's Avatar
hey guys,
Thinking about replacing my clutch master cylinder since it has no cap. I've tried looking around and picked up caps off cylinders from other YJ's but they don't fit. This leads me to believe that the previous owner had the cylinder replaced with an aftermarket one.
Now my question is, I've heard that it's best to replace both the master and slave since replacing one puts stress on the other, is this true?
Basically, I don't want to drop my tranny to replace the slave.
What should I do?
'02 WJ, Laredo Special Edition, 4.0L I6
Johnny World is offline
post #2 of 8 Old 05-19-2006, 02:28 PM
Omega_9x
In the time I've had My jeep, I'm on My second replacement. The first one was a cheapy plastic housing. Somehow, the return spring inside the unit broke into 4 pieces. but I spent 80 dollars on a nice aluminum one, had no problems since. I haven't had to replace the slave, but I should probably look into it.
If You get a new master, You shouldn't have any problems if You leave the slave alone really.
'93 YJ: 35x12.50 15 BF Goodrich AT KO on Mickey T. Classic II's, Tom Woods Custom CV Shaft, 3-4 inch springs (Brand Unknown) 2" Shackles, 1" Red Poly BL, 4.10 Yukon Gears, Powertrax No-Slip Locker, BW Pocket Flares, BW Rocker Panel Guards, Outland Hi-Back Bucket seats
Omega_9x is offline
post #3 of 8 Old 05-19-2006, 02:44 PM Thread Starter
Johnny World
Do you have a link to the one you bought? Was it difficut to install?
post #4 of 8 Old 05-19-2006, 03:04 PM
Omega_9x
No, it was direct from the store, I had to thumb it into town unfortunately. It's not hard at all to install. Can get mesy tho.
Omega_9x is offline
post #5 of 8 Old 05-19-2006, 03:55 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
stay away from the parts store brands. nothing but trouble when it comes to these things. if it fits your 90, you're welcome to my old one. bout a year and a half old and a dealer part. i went through 3 of the parts store versions before getting fed up and dropping the big bucks on the mopar master. never had a problem with it after that. only reason i'm getting rid of it is because i've since switched to an external slave setup since i've had that go on me 3 times since buying the jeep in 02. PM me if you're interested.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #6 of 8 Old 05-19-2006, 05:06 PM
azgurney
I have never replaced my slave but had to replace the master several years ago. Unless you want to do the job over in a year or so do not buy the part from auto zone etc. My Auto Zone master lasted about a year then went bad. It was very cheaply made. I then put on a new original equipment master and have not had any problems.
91 Wrangler 4.0 5sp
8.8 4.10 explorer axle, 33x12.50x15 x-terrains,Rancho 2.5 lift and shocks, Goforit 1" motor mount lift, 1" body lift, sailcloth top with tinted windows
azgurney is offline
post #7 of 8 Old 05-19-2006, 05:14 PM
sentinal02
sentinal02's Avatar
wow you got a year? none of the 3 i bought (2 from AZ, one from Advance) lasted more than a month
post #8 of 8 Old 05-19-2006, 05:38 PM
Omega_9x
Heh, I guess I got lucky with mine, I've had it for over a year now with no trouble.
Omega_9x is offline
Clutch master cylinder replacement Mean Max YJ Wrangler Technical Forum 107 09-26-2014 03:06 PM
Clutch Master Cylinder Replacement biasdesign YJ Wrangler Technical Forum 5 07-28-2009 06:27 AM
'88 YJ clutch master cylinder replacement BlackSheep92 YJ Wrangler Technical Forum 0 05-05-2008 09:42 AM
clutch master cylinder replacement ? freakydiver YJ Wrangler Technical Forum 6 02-20-2006 04:30 PM
Master/slave clutch cylinder replacement 95 SaucerBoy YJ Wrangler Technical Forum 15 08-15-2005 04:13 PM
