need wiring diagram for aw4 swap - JeepForum.com
post #1 of 6 Old 02-18-2010, 08:47 AM Thread Starter
cwjeep
need wiring diagram for aw4 swap into 87 yj for it to shift fully auto
cwjeep is offline
post #2 of 6 Old 02-18-2010, 10:18 AM
dadstoy
Maybe someone makes something that works, but the AW 4 has to tie into the PCM, or at least mine did. Does the 4.2 have a CPS? That also ties into the AW 4 controller.
Seems like I saw something somewhere, that was a controller for the AW 4 that all you had to do was bring 12V to it and tie it into the TCM, but I can't find the link. You could either manually shift it or let it auto shift. Seems like the price was around $180...........
dadstoy is offline
post #3 of 6 Old 02-18-2010, 10:30 AM
jbolty
jbolty's Avatar
Found this a while back, no personal experience with it
Shifter lineup
jbolty is offline
post #4 of 6 Old 02-18-2010, 11:53 AM
dadstoy
Yea, that's the one I saw
dadstoy is offline
post #5 of 6 Old 02-19-2010, 09:42 PM Thread Starter
cwjeep
trans is in. will work on driveshaft,wiring,and cross member saturday.
cwjeep is offline
post #6 of 6 Old 02-20-2010, 06:11 AM
dodger889
Here is a site that might help. But you can wire the tcu with out tying into the emc they only shared a connection for the controlling the trans. Now you will need a vss and to run a power lines.
here is a link that might help. Wiring Introduction
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
Need a 91 YJ wiring diagram....HELP PLEASE! danheit YJ Wrangler Technical Forum 1 01-11-2009 09:19 AM
need wiring diagram majkowskid TJ Wrangler Technical Forum 4 07-18-2008 07:04 AM
'87 YJ Wiring diagram wwest76 YJ Wrangler Technical Forum 1 01-21-2007 04:16 PM
Need Wiring Diagram Krisfyr TJ Wrangler Technical Forum 3 06-06-2006 12:03 PM
