Need Transfer Case Skid Plate!!! - JeepForum.com
post #1 of 4 Old 11-22-2008, 02:40 PM Thread Starter
fataltherabbit
If anyone can direct me were to find a Tcase Skid plate that would be great , Im looking like 40 - 50 bucks ish ? used or new Ither way its all good
this is my problem
Thanks in Advance
1990 YJ ,2.5 AX-5 4.10's 4.5'' l 33''hawgs, 2KC's
2 55watt, Custom Bar, Discos. -- An Finally got a Softop!!!!
" I'd Hate to Advocate Drugs, Violence, Guns or Insanity .. but they have always worked for me" - Hunter S. Thompson
Jeep Build - 11,550$
Sunday.Drivers.
fataltherabbit is offline
post #2 of 4 Old 11-22-2008, 03:39 PM
scherb53
Looks like you got some frame rust/rot issues... that one bolt is pulled right out of the frame. A new skid plate won't help that situation. I would check all the rest of the frame to see if its worth while repairing if not then perhaps a new frame is in order
scherb53 is offline
post #3 of 4 Old 11-22-2008, 04:41 PM
jeepercreeper77
jeepercreeper77's Avatar
i looked around for one myself and could only find the belly up type and a new stock one from the dealer.
90 wrangler,4.2l,1" MML,CRT HEI Dist.,34/34(interco) weber, hurst shftr,5spd,5" BDS lft,f-d30/r-8.8,5/8 lft booms,1" bl,tflex belly up,JB convs. SYE,gdyr mtr35s,hurc'ed,smit src frt bump,gen-r rear bump w/tire carrier,f&r tube fenders,psc knokrs,r gen-rgt ful conr gurds,duel bat.,BIC,m8000
jeepercreeper77 is offline
post #4 of 4 Old 11-22-2008, 06:08 PM
pasinbuy
Dude, you have bigger problems than just a skid plate. The frame rot at the back bolt looks pretty bad.
I might think about a new/used frame.
pasinbuy is offline
Transfer Case Skid Plate Billyjon1 TJ Wrangler Technical Forum 1 02-11-2009 03:01 PM
Skid Plate over transfer case RubiconsR4Grls2 TJ Wrangler Technical Forum 9 11-13-2007 11:22 AM
Transfer Case Skid Plate ntxjetta YJ Wrangler Technical Forum 6 02-13-2007 05:56 PM
Help can't get transfer case skid plate off patphish TJ Wrangler Technical Forum 20 10-16-2006 06:15 PM
transfer case skid plate 86comanche TJ Wrangler Technical Forum 7 04-12-2005 09:31 AM
