Need tech help: intermittent wipers - JeepForum.com
post #1 of 3 Old 11-11-2001, 04:01 PM Thread Starter
m10e
My wipers just stoped. fuse is good, & I just read that I have to take my hard top off & fold down the front window to check the wiper motor. Is it common for yj's wipers to crap out. I hope it is not the swich. I would like to know if there is an easy way to test the wiring to see what has power after the fuse. But I'll be damned if I can find the right wiring coming in or out of the steering collum.
93 YJ, Jet Black/w Dark Glass. 31x11.50, I only have 4 FI Squirrels under the hood "& I think one is sick right now." I love 4x4'n in central Idaho...
If you live around Lewiston ID email me,
m10e is offline
post #2 of 3 Old 11-12-2001, 01:18 AM
Ruftags
The typical colors for wires and associations is BL(blue) for the wipers up, GY(gray) for wipers down, These two are the direct for the motor itself. There is a RD(red) for HI, WT(white) for LO and BK(black) ground. These should be the wires from motor to a plug. The wires on the other side of the plug line up this way. WT to WT/BK(white with a black tracer stripe), GY to TN/RD, RD to BL/YL,
The BL to LG/BL(this goes to the w/wiper circuit breaker) Then to module under the instrument panel next to steering column that goes to battery.
BK to BK that goes to a splice then to a ground. The other 3 go straight to a module under the instrument panel next to steering column. The wires coming out of the switch goto the same module this way. Off(YL) to off, Low(GY) to low input, Delay(DG) to pulsemode signal input, Hi(VT-violet) to hi input,Delay(BR)to pulse mode time input. PK to washer pump. The WT wire ties the off selection of mist and wash in switch to wiper/washer switch power in module. I hope this helps out enough to at least hook up some jumpers to test the motor and to check continuity of the switch.
95 YJ 2.5L AX5 30in. rubber.
So many upgrades/So little cash!!
Ruftags is offline
post #3 of 3 Old 11-12-2001, 07:47 AM Thread Starter
m10e
Thanks, I will give it a try tonight. Just to see if it is the Switch or the Motor.
m10e is offline
no intermittent wipers joeyrossmiller YJ Wrangler Technical Forum 14 10-14-2009 08:07 PM
intermittent wipers netabass51 TJ Wrangler Technical Forum 5 02-03-2009 12:33 PM
intermittent wipers D_Dude2000 YJ Wrangler Technical Forum 6 10-19-2006 07:28 AM
Intermittent Wipers? Smash209 YJ Wrangler Technical Forum 5 09-06-2006 12:18 PM
Intermittent Wipers Dan Marino YJ Wrangler Technical Forum 7 12-02-2005 06:58 AM
